Stock Width Replacment LCA
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blackdawg, Sep 23, 2015.
  1. Apr 15, 2016 at 1:50 PM
    #201
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    More rake will make it easier, not harder, to get more positive caster.
    jberry813 likes this.
  2. Apr 15, 2016 at 2:00 PM
    #202
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Rake lifts the rear up, tilting the front upper ball joints forward, reducing caster.
  3. Apr 15, 2016 at 2:12 PM
    #203
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    I mean, technically this is true, but you'd have to have to serious take to throw off your alignment
  4. Apr 15, 2016 at 2:55 PM
    #204
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I never measured my stock length arms, but I have the most caster at full bump and the least caster at full droop. Raising the rear would further load the front (more bump)...which in turn would increase caster.
    You can see here at full droop how the UCA uniball pushes forward and has the least amount of caster.
    Doesn't take as much as you think. I realign my front end any time I adjust the ride height front or rear.
  5. Apr 15, 2016 at 3:06 PM
    #205
    Digiratus
    Roaming the PNW
    The RedHead
    I've been told on more than one occasion by alignment techs that leveling the truck (removing the rake) makes it harder to get higher caster numbers. :notsure:
  6. Apr 15, 2016 at 4:54 PM
    #206
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    From a straight geometric perspective, rake/caster is a one to one relationship. 1 deg of increased rake equals 1 less deg of caster. "Loading" the front from raising the rear negates this bit. To accurately describe "a bit" other factors such as "amount", spring rate, spring load at ride height and actual vehicle weight distribution need to be considered.
    Geometrically on an extra cab, just a hair under 2" rake (higher rear) equals 1 deg less caster.
    For Mr Bravo's case something is wrong, he should easily get in excess of "factory" caster spec unless his rear (no weight) is a foot higher than the front.
    Willbeck likes this.
  7. Apr 15, 2016 at 5:22 PM
    #207
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Ok. Thanks guys. I'll check back when I have the load on the back and see if that helps.
  8. Oct 27, 2016 at 2:56 PM
    #208
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Bump - did it help any? Did you ever get the + caster you were after? I'm having the same issue and now I'm wondering if I have a rake. I am running AP Expo leafs w/ King ext. and AP ucas.
  9. Nov 4, 2016 at 10:44 AM
    #209
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Hiya guys.
    The shop set an alignment to reduce wear and the tires have been wearing well. Granted they are 10ply. My old Revos ran for like 8 years with almost no wear since the truck is so light.
    I'm still not sure I believe the caster measurements the alignment shop showed. I think with the rear end being high and the fact that the computer wouldn't allow the entry of non-stock tire sizes might have something to do with the reading. In other words I still don't know if I have the caster I was hoping for.
    I will get the bed on in December.
