Stolen Catalytic Converter !!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pro1967, Feb 4, 2017.
  1. Feb 4, 2017 at 5:57 PM
    Pro1967
    Pro1967 [OP] Member
    My wife has a 2004 Reg. Cab PreRunner, 2.7L, Auto, w/a 113k miles (Well someone took it upon they're selves to STEAL her "Catalytic Converter" yesterday at her work in an open parkin-lot in the middle of the day at a hospital on the good side of town... Ball-zzz) so today I pay $250. for a "Dynomax" OEM specs direct bolt in. ****NOW IS WHERE THE PROBLEM STARTS**** The Truck will not start... It will turn over but will not start/run, pulled a coil & plug and it has Fire... & I smell fuel "but" I dont hear the fuel Pump ! *** IS THERE ANYONE HERE CAN TELL BE WHERE THE FUEL PUMP RELAY & FUSE OR FUSES ARE LOCATED ? *** The Engine Light is showing but its code is a EVAP (GAS CAP) ~~~ H.E.L.P.~~~
  2. Feb 4, 2017 at 5:59 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    :eek: wow that's ridiculous lol ive heard some pare tires and tailgates but a damn cat. that really sucks
  3. Feb 4, 2017 at 6:02 PM
    Pro1967
    Pro1967 [OP] Member
    SUCKS INDEED !!!
  4. Feb 4, 2017 at 6:03 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You aren't the first! Really easy access under there unfortunately. I had mine stolen off my old Prerunner in high school.
  5. Feb 4, 2017 at 6:10 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    The guy needs help. Someone can chime in here?
    As previously covered on TW, crack head steals cat for the precious metals inside and cash he will receive from unscrupulous wrecker. Convo done.
    Please stay on topic and help the guy out.
  6. Feb 4, 2017 at 6:10 PM
    Fast Frank
    Fast Frank Member
    Frank
    Houston, Texas (The Woodlands)
    2017 DCSB 4X4 OffRoad
    O.K.- Here's what happened...
    Some knothead slid under your truck with a battery operated saws-all and cut the exhaust pipe in front of and behind the cat.
    He then slid out with it and hauled ass.
    Then, you started the truck, and was amazed at the incredible noise it made. Probably drove it, too.
    After that, Some Other Knothead at a muffler shop was under there with either a welder, or a cutting torch, or a grinder, and probably all three.
    And then it wouldn't start.
    I'm going to go out on a limb and say that something else was damaged.
    Slide under the truck, and look. Check out the area where all the cutting and welding was done. Do you see any wires?
    The O2 sensor should be right there. Is it new? Are the wires intact? Is it all taped up?
    The O2 sensor has power going to it from the ECU. If you short out the O2 sensor, it will blow a fuse in the fuse box under the hood.
    theredofshaw, ThunderOne and taczilla like this.
  7. Feb 4, 2017 at 6:13 PM
    Pro1967
    Pro1967 [OP] Member
  8. Feb 4, 2017 at 6:17 PM
    taczilla
    Marc
    2016 RAM Rebel
    blank post
    :notsure:
  9. Feb 4, 2017 at 6:20 PM
    Pro1967
    Pro1967 [OP] Member
    My wife cranked the truck and instantly turned it off as soon as she her noise & smelled gas (It ran for maybe 5 - 10 seconds total & Luckily I own a tow truck & for as the Cat Conv. I simply unbolted the the factory bolts and bolted the new in its place, Checked all wires for front to back
  10. Feb 4, 2017 at 6:25 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    I'm doing some googling and someone on TN said its on the left of the steering column behind the top of the lower dash access panel. hard to find but its in there I'm doing some more research to confirm
    ZachPrerunner likes this.
  11. Feb 4, 2017 at 6:26 PM
    Pro1967
    Pro1967 [OP] Member
    thanks so much... Ive look all dang day...
  12. Feb 4, 2017 at 6:31 PM
    Pro1967
    Pro1967 [OP] Member
  13. Feb 4, 2017 at 6:33 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    cant see the img but apparently it should be where ur left knee would be while driving
  14. Feb 4, 2017 at 6:34 PM
    Aw9d
    Aw9d That one guy
    Check all of your fuses as well. Wires might of been ripped apart and grounded out
  15. Feb 4, 2017 at 6:35 PM
    Pro1967
    Pro1967 [OP] Member
    Im going back to the shop tomorrow, I had to leave today before I started setting fires around it & knocking out windows...
    theredofshaw and Bocsy44 like this.
  16. Feb 4, 2017 at 6:38 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    well there should be a ECI relay under the hood as well as an opening circuit relay under the dash. Good luck tmrw hope you figure everything out!
    Aw9d likes this.
  17. Feb 4, 2017 at 6:39 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If you smell gas, I'm guessing a fuel line was cut as well.
    Please update.
  18. Feb 4, 2017 at 6:40 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    he meant he smelled fuel in the cylinder after pulling the spark plug
    Pro1967[OP] likes this.
  19. Feb 4, 2017 at 6:44 PM
    Pro1967
    Pro1967 [OP] Member
    fuel lines are spot-less w/no leaks "only fumes" Thanks for the helpful tips & hints...
  20. Feb 4, 2017 at 6:46 PM
    koditten
    Kirk
    Central Michigan
    The code was for evap. Loss of fuel system pressure. if the cap is on, then there is a leak somewhere else. The fuel line or fuel return line may have been cut.
    The fuel pump relay is under the hood in the big fuse box and the fuel pump is in the tank. Can you hear the pump running with just the key turned to the "on" position?
