Stony Pass 12 Sep 2021 and others
Discussion in 'Trip Reports' started by muddog321, Sep 23, 2021.
  1. Sep 23, 2021 at 7:56 PM
    muddog321
    muddog321 [OP] Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Took Stony Pass over from Lake City CO to the Silverton side 36 miles with the 1st 18 smooth road till mile 18 when you start going up. Lots of loose rock on all the roads in the Alpine Loop area. Bear hunters out scouting so tons of UTVs and 4 wheelers around. Cross pole creek going up. At the top of the pass you can hike 1.7 miles up and 1.7 miles back at 12,500 ft along the Continental Divide trail to the Rio Grande river headwaters and see the small spring where it starts.
    smallfrye likes this.
  2. Sep 24, 2021 at 3:26 AM
    smallfrye
    smallfrye Well-Known Member
    Stock
    Drove that trail a few months ago, good times.
