Stoopid Noobs Question, Part 5: Calculating Tire Size from Rim Size
Discussion in 'Wheels & Tires' started by 28ØØ3, Jan 23, 2009.
  1. Jan 23, 2009 at 7:39 PM
    28ØØ3
    28ØØ3 [OP] Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
  2. Jan 23, 2009 at 8:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Example:
    265/75/17=
    265 is the sectional width in mm
    75 means the tire sidewall is 75% of the width (x2)
    17 is the rim dia.
  3. Jan 23, 2009 at 8:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    So, If you want the same width tire, on a different wheel, you have to look for a smaller sidewall height. a 265/75/16 is the same height and width as a 265/70/17
  4. Jan 23, 2009 at 8:22 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2 on this one.;)
  5. Jan 24, 2009 at 4:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Many tires have a listing for recomended wheel width. A 285 will fit quite well on a 9" wide wheel, but a 325 width tire may need a 10" wide wheel.
  6. Jan 24, 2009 at 4:11 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    What he said. My 285s are recommended for rim width between 7.5" and 9".
