Stop and start driveline movment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Huskerjim, Apr 24, 2009.
  1. Apr 24, 2009 at 7:32 PM
    Huskerjim
    Huskerjim [OP] You gotta love your brother inlaw!
    Jim
    Fleming Island, Florida
    4x4 TRD Sport
    Ballistic Wheels Nitto Tires Extang Cover Exhaust Duel Leather Interior OEM Bug Shield Bullet Grill and Ect. Bed Mat
    I have a 05 taco trd 4x4 when I stop and take off from a stop sign I feel a little jolt like a little slop in the driveline is that normal? The dealer says yes I feel it's different. I own a 07 GMC Denali AWD 4x4 I hear driveline movement but not the feel. HAs any one else felt this and is it normal?
  2. Apr 24, 2009 at 7:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like Axel wrap. It is normal on Automatic equiped Tacomas.
  3. Apr 24, 2009 at 7:35 PM
    Huskerjim
    Jim
    4x4 TRD Sport
    Oops forgot to say it is a Auto too. So what exactly is that? Axle Wrap:confused::confused::confused:
  4. Apr 24, 2009 at 7:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When comming to a stop, the drive shaft and rear axel are under a torqe load, as the tranny is still aplying power to the diff. This twists the DS and Rear end up a little bit, as the Tacoma springs are long, and a softer spring rate, than most other trucks. The brakes hold the rear end in this position, then when the brakes are released, you hear/feel a "thump" or "Clunk" as the rear axel pivots back to its original position. It can be fixed with an AAL (Add A Leaf), but this will aslo give you more lift in the rear. Some people have claimed to have fixed this issue by greaseing the slip joint on the drive shaft, but I dont think this is a good way to fix the issue, as by doing so, stress is now applied to the pinion seal in the third member.
  5. Apr 24, 2009 at 7:45 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Isn't the slip joint sealed? How are people greasing it?
  6. Apr 24, 2009 at 7:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On the new ones, they are, but on the First gens, they can be greased.
  7. Apr 24, 2009 at 7:49 PM
    Huskerjim
    Jim
    4x4 TRD Sport
    Thanks that makes sense... As long as it's normal I can live with it, you guys are are abso;utley awesome!!!
  8. Apr 24, 2009 at 7:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :proposetoast:
