Stop brake squeak
Discussion in 'Technical Chat' started by rondog, Nov 15, 2010.
  1. Nov 15, 2010 at 2:01 PM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    How can I stop the squeaking in my brakes ? I just replaced them and every once in a while (mostly when I brake lightly) I can hear a squeak? Any ideas? Thanks.
  2. Nov 15, 2010 at 2:13 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
  3. Nov 19, 2010 at 7:57 PM
    McBride513
    McBride513 Well-Known Member
    Luke
    Cincinnati
    04 4x4 TRD
    did you lube the back of the pads, caliper slides, or any of the other moving contact points?
  4. Nov 19, 2010 at 7:58 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Grease the rotors.:D
  5. Nov 19, 2010 at 8:00 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    X2
  6. Nov 19, 2010 at 8:01 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Are they good brakes? Cheapo pads/rotors will squeak no matter what you do.
  7. Nov 19, 2010 at 8:04 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    ^^This^^
    with this
  8. Nov 19, 2010 at 8:52 PM
    rondog
    Ronnie
    Escondido/San Diego
    No I didnt lube anything..must be why lol
  9. Nov 19, 2010 at 9:00 PM
    afd23a
    The Dynamo of Dixie
    try some lube between the shims and the pads and between the shims and the caliper piston
  10. Nov 19, 2010 at 9:25 PM
    soccerkidbs
    soccerkidbs Active Member
    Brandon
    Southern Oregon
    2002 D\C Prerunner SR5 TRD
    6000k HID Head light kit, K&N CAI, 2" revtek lift, LED map lights
    Mine also squeak when breaking lightly. I am going to try lubing everything.
  11. Nov 19, 2010 at 9:28 PM
    Sullyman
    Sullyman Crusty ole' conservative fart
    Augusta, Georgia area
    2010 Black TRD Sport
    Cat-back exhaust, BluLogic, Back-up Camera, Extang Solid Fold Tonnau cover, Pop-n-Lock PL8521 electronic tailgate lock, Illuminated 4x4 switch, Smittybuilt Nerf Step Bars, Toyota bed mat, Tinted the windows darker, CB with custom fab'd antenna mount, Grillcraft grill, AFE Pro Dry S filter with secondary filter removed. Differential breather relocation mod. Bridgestone Dueler AT/Revo 3 tires Weathertech mats Spec-D HID Halo's Bilstein 5100s front set at 2.5" w/OEM springs 4-leaf TSB w/ SkyJacker add-a-leaf 2" block lift 1.5" wheel spacers Freedom Off-Road upper control arms .5" coil spacers ATOTO A6 Android double-din head unit
    I tried that several times on my old 4Runner with no joy...I'd try the lube...
  12. Nov 20, 2010 at 3:17 PM
    McBride513
    Luke
    Cincinnati
    04 4x4 TRD
    if the shims aren't rivited on, take them off
  13. Nov 20, 2010 at 3:44 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    This stuff is NOT a lubricant. You're supposed to put it on the backside of the pads (closest to the piston head). It's a thick & sticky goo that you spray on. It's supposed to take out the 'slack' between the pad & the rotor to prevent squeeking.
  14. Nov 21, 2010 at 2:56 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    THIS is a brake lubricant, only thing I use. Don't expect to go finding it at your local auto parts store thought. Can get it online for $20.
    Castle Brake Life.
    Most superior brake lubricant today. Silicone. Use it for metal to metal contact, use it for rubber to metal contact. Literally use it for everthing on ANY brake (Disc or Drum) system that needs lubrication. Water resistant.
  15. Dec 2, 2010 at 10:28 PM
    pyro13g
    pyro13g Well-Known Member
    Will
    Florida
    07 Tacoma Access Cab 4-CYL 5-Lug
    2.5" Lift, Add A Leaf, ridding on 30's, Sound Mat in floors and doors
    I am having the same problem on my 07 Tacoma but my squeak is coming from the rear drums and they were just installed less than 1500 miles ago... It only happens when i brake lightly and about at a full stop. I installed the front brakes myself and used brake grease behind the pads, on the pistons, and all moving part areas (except on pad insides or rotors) and that works great! Just can figure out why the rear drums squeak at almost full stop.
    Any Ideas?
  16. Dec 3, 2010 at 12:57 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    I don't know your mileage but are you trying to say that you put new rear brake drums on your 07 already?
    Typically the type of squeak you're describing is brake dust build up inside the drum and and can usually be eliminated by spraying the brake shoes, hardwardware and springs down with brake cleaner, doing the same on the inside of the drum and wiping the inside with a clean rag. Adjust the brake shoes when done cleaning.
    If it is new drums,(and new brake shoes??) something may not have gotten lubed on the backing plate or an anchor point. They might also need a little adjusting. Just have both checked, make sure it's all correctly lubed at shoe contact and pivot points and get a good adjustment on them.
  17. Dec 5, 2010 at 11:28 AM
    pyro13g
    Will
    Florida
    New shoes were installed by Firestone and the truck has 67XXX miles on it so i dont think its anywhere near time for new drums. Th drums were put on a lathe and cleaned up. Im hoping my money i spent for Firestone to install these shoes was done correctly. Funny how I installed the front brakes myself and they work perfectly and were done correctly with grease the correct pads and rotating the rotters but some "professional" F***'s up the rears and i look like a a$$ when i pull up to a light with squeaking breaks... Thanks for the reply Quaker
  18. Dec 8, 2010 at 8:29 PM
    teamplayer
    teamplayer Active Member
    mario
    florida
    tacoma trd sport
    rims,painted parts,train horn for all those pleople texting with their phones,hid,painted engine cover,k&n air filter,leds floor lights.
    i replace my brake pads and still makes noise when i brake slowly , and they are oem brakes,any ideas
  19. Dec 8, 2010 at 10:24 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    New rear shoes at 67K and machined the drums is what you had done then? Did you also get new a new hardware kit placed in? (hardware = new springs, hold down clips)
    Hmmm....gotta be a missed lube spot(s) or adjustment.
    If you had this done not all long ago, take it back. Since it was firestone, maybe try a different shop as well.
  20. Dec 8, 2010 at 10:30 PM
    pinktaco808
    pinktaco808 Hot Steppa
    wat bout the drum brakes
