Stop Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ODICA, Sep 11, 2011.
  1. Sep 11, 2011 at 7:54 PM
    ODICA
    ODICA [OP] 06 TACOMA 4X4
    Earl
    Beaumont, CA
    06 4X4 SR5
    I need some help troubleshooting my stop light in my truck. My stop light went out, and I had checked the fuse box in the engine compartment, and the fuse box under the steering wheel but found all the fuses in good condition. Is there anywhere else I need to check as far fuses our concern?
    Thanks for the time fellas!
  2. Sep 11, 2011 at 7:56 PM
    CUtigerfan
    CUtigerfan Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    brake lights? check the bulbs maybe?
  3. Sep 11, 2011 at 8:03 PM
    ODICA
    Earl
    Beaumont, CA
    06 4X4 SR5
    Yes brake lights. I had checked all the bulbs including 3rd brake light and everything checked out.
  4. Sep 11, 2011 at 8:11 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Check the fuse box under the steering wheel one more time, Fuse labeled "GUAG" 7.5a
  5. Sep 11, 2011 at 8:12 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Which light went out? If all of them died at the same time, it's likely an electrical/fuseproblem.
  6. Sep 11, 2011 at 8:18 PM
    joes06tacoma
    Joe
    Central Coast, CA
    http://www.ncttora.com/fsm/05+/data/ileaf/06toyewd/06toypdf/ewd/2006/tacoma/h/em01d.pdf
    If I read that right, you should be looking for a 10 amp fuse in the engine compartment.
    http://www.ncttora.com/fsm/05+/data/ileaf/06toyewd/06toypdf/ewd/2006/tacoma/h/em01d12.pdf
    According to this, the only other thing between the fuse and the brake lights is the brake light switch. I would be looking for power down there with a digital voltmeter. Don't use a test light, if you get the wrong wire it can set off the airbag.
    It could also be a bad ground, but the center stoplight grounds differently than the two lower stoplights, so if they are all out I think your grounds are okay.
    Edit: looks like there is a relay in there as well.
  7. Sep 11, 2011 at 8:19 PM
    ODICA
    Earl
    Beaumont, CA
    06 4X4 SR5
    All the brake lights went out. I had checked the fuse under the steering wheel again but everything checked out good.
  8. Sep 11, 2011 at 8:31 PM
    joes06tacoma
    Joe
    Central Coast, CA
    There should be a "stop lamp control relay" under the hood also if you have traction control. I thought that the double cabs all had that? Maybe pull that out and see if there is another relay you can swap it with for testing?
    Other than that I think you are going to have to get a meter and start following the voltage check points on the wiring schematic.
  9. Sep 11, 2011 at 8:37 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Did you replace the fuses? Sometimes with the mini fuses they are hard to tell that they are blown.
  10. Sep 14, 2011 at 1:47 PM
    tacomunchkin
    tacomunchkin Well-Known Member
    Navarre FL
    2010 TRD Offroad
    2010 4x4 Offroad TRD Crew cab 4.0 TRD Cat-Back exhaust CAI Avid offroad sliders and light bar PIAA 520 ATP lamps Leer bed shell
    I thought this was going to be a thread about improving your mpg by ignoring stoplights.
  11. Sep 14, 2011 at 1:49 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    :laughing:
  12. Sep 14, 2011 at 2:10 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    Brake light switch maybe. Happened in one of my other cars
  13. Sep 14, 2011 at 4:17 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    this would be my guess also. if none of em work this has to be the reason
