Stopping issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomalife89, Apr 10, 2023.
  1. Apr 10, 2023 at 2:25 PM
    Tacomalife89
    Tacomalife89 [OP] New Member
    2008 Toyota tacoma
    Aftermarket cold air intake
    Hello everyone, new to this website I recently bought a 2008 Tacoma 4.0 with a automatic transmission and I just made my first hard stop in traffic today due to someone cutting me off and I noticed that about 15 seconds after stopping the truck jerked forward it felt as if someone rear ended me but no one did. Does anyone have any advice on what this could be from? Thank you guys in advance
  2. Apr 10, 2023 at 2:29 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW
    Probably axle wrap.
    Tacomalife89[OP] and asuchemist like this.
  3. Apr 10, 2023 at 2:33 PM
    Tacomalife89
    2008 Toyota tacoma
    Thank you! I will look into replacing them right now it was a nerve wracking experience
  4. Apr 10, 2023 at 2:35 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    how flat are the rear leaf springs? mine does that even worse with a trailer or a load in the bed
  5. Apr 10, 2023 at 2:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Nothing to panic about. Make sure the leaf springs are not broken and the ubolts are torqued to spec and don't worry about it. I found mine were loose from the factory on 2012 and torqued them to 95 Ft Lbs and haven't had any issues since.
  6. Apr 10, 2023 at 3:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    15 seconds after you stopped?
    Did this happen right when you let off the brake pedal?
    Or were you still pressing the pedal.
    The AC compressor kicking on in the 4.0 will cause a feeling of someone tapping your rear bumper like you described.
    tcjacado and Tacomalife89[OP] like this.
  7. Apr 10, 2023 at 3:31 PM
    Tacomalife89
    2008 Toyota tacoma
    Thank you guys
  8. Apr 10, 2023 at 3:33 PM
    Flo_TRD07
    Flo_TRD07 Well-Known Member
    Ben
    2007 Tacoma TRD Sport Prerunner
    Truck things
    Wait…. what?? I’ve never heard of this:confused::confused:
  9. Apr 10, 2023 at 3:35 PM
    Tacomalife89
    2008 Toyota tacoma
    No sir this happened while at a complete stop. I just went out for another test drive and did a hard brake on purpose just to see and it did it again it feel’s almost like a transmission issue as if I braked to hard and the transmission didn’t have time to down shift if that makes any sense
  10. Apr 10, 2023 at 3:39 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    I have this on my 2015 Tacoma with 88k miles.
    I’ll drive on the highway, get off and pull up to a set of lights. Normal braking…..then once I stop, about 3-5 seconds later, there is a slight kick….
    my g37 did the same.
    Not sure, but my theory is that when you break, your truck tries to stay in 2nd gear in case you don’t stop all the way…..but once you stop completely….the trucks realizes that and shifts down to first.
  11. Apr 10, 2023 at 3:47 PM
    TnShooter
    Deogee
    STOCK
    Yeah, when the compressor kicks on, it ups the idle speed.
    Mine does it, others have reported the issue also.
    The fix is to press the brake harder:thumbsup:
    tcjacado likes this.
  12. Apr 10, 2023 at 3:49 PM
    TnShooter
    Deogee
    STOCK
    It’s possible the transmission fluid is low.
    I kind of remember another member here having the transmission “bang” into gear when stopping.
    The fluid was low, after getting it back to the correct level, all was good.
    winkel, tcjacado and wilcam47 like this.
  13. Apr 10, 2023 at 4:04 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    You’re right on the fix lol. But Mine does it even when AC isn’t on. But it does always correspond to an increase in idle speed/RPM when stopped in gear. Doesn’t do it when I coast to a stop in neutral. I thought it was just increased torque from the trans downshifting and higher rpm.
    the power steering pump also has an idle up switch, FYI
    TnShooter[QUOTED] likes this.
  14. Apr 10, 2023 at 4:21 PM
    Waasheem
    Waasheem
    2007 xrunner
    My theory. When hard breaking, the front squats, the rear lifts, then once stopped the suspension levels out but the wheels are stopped putting odd push and pull loads on the suspension. Then when you let up on the brake pedal, those loads are released so you could feel a jolt or hear creaking.
  15. Apr 10, 2023 at 4:23 PM
    TnShooter
    Deogee
    STOCK
    Except OP says he isn’t letting off the brake.
    It happens completely stopped. I suppose the suspension might settle, but I would think it would be a hard as OP says?
  16. Apr 10, 2023 at 4:46 PM
    bret
    bret Well-Known Member
    bret
    harpers ferry wv
    05 ac trd sport
    axle wrap unwrapping
