Stoptech Big Brake Kit Group Buy 2005-2017 Tacoma and Others
Discussion in 'Automotive Group Buys' started by Iggy, Oct 17, 2016.
  1. Dec 6, 2016 at 5:08 PM
    #181
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    The fat bitch can stop again
  2. Dec 7, 2016 at 5:33 AM
    #182
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So all of you guys with the added weight of LT kits, bigger tires, and whatnot.... are you all noticing a improvement in stopping capability?
    This is a redundant question, but I would still greatly appreciate you all's feedbacks.
    tacoma16 and Biscuits like this.
  3. Dec 7, 2016 at 6:21 AM
    #183
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Hell yes. I can actually get the abs to engage now.
    tacoma16, Biscuits, Drainbung and 2 others like this.
  4. Dec 7, 2016 at 8:06 PM
    #184
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Damn 16" wheels...
  5. Dec 7, 2016 at 9:44 PM
    #185
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    To be honest, for my daily driving usage, I only noticed a marginal improvement over the Centric rotors and Porterfield pads that I ran with the stock calipers. The initial bite when braking isn't as strong so come spring time, I plan to swap to more aggressive pads. I will probably go with Porterfield again.
    One of the main reasons why I picked up this kit for for towing, but I haven't had a chance to tow anything since the upgrade.
    I also wanted to add that maybe I was expecting more from the kit. Years ago, I have a 2004 Silverado with a Baer 4-piston BBK and that thing stopped on a dime. Brake dust was crazy, but it stopped like a sports car. It was a street truck and I'm sure the ZR rated tires played a big role in the performance compared to the MT on the Tacoma now, but I was hoping for more with this 6-piston kit.
    Vanguard, Iggy[OP] and Torspd[QUOTED] like this.
  6. Dec 8, 2016 at 5:03 AM
    #186
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which pads came with the kits?
  7. Dec 8, 2016 at 6:30 AM
    #187
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Did you bed the pads in? Mine was kinda shitty on initial bite too until I went out and bedded the hell out of them. That and I had to bleed the fronts several times to get all the air out.
  8. Dec 8, 2016 at 6:57 AM
    #188
    Biscuits
    Mityvac makes a few different brake bleeder kits that make very short work of bleeding the air out of the brake lines.
  9. Dec 8, 2016 at 7:15 AM
    #189
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It wasn't lines. It was air in the calipers. It happens with brand new calipers. I normally bleed, drive/bed, and then bleed again once they cool down. Tapping the calipers with a dead blow helps too.
    Toynado likes this.
  10. Dec 8, 2016 at 8:31 AM
    #190
    Biscuits
    Ah, okay. I don't think I've ever run into that issue before, then again I can't remember the last time I had to replace a caliper. I appreciate your response.
  11. Dec 8, 2016 at 8:44 AM
    #191
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    On another note,
    I do have to hand it to SOS. I wanted the black calipers, and by the time I ordered the black was out of stock. SOS stayed in communication with me via text and even sent me a second set of pads for waiting the 3 weeks while they got black back in stock. All in all, really good customer service.
  12. Dec 8, 2016 at 8:46 AM
    #192
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Yeah! They are super fast at communicating.
    They said a 16" kit is possible with two price rotors because it's the size they need for the 16" only comes that way.
  13. Dec 8, 2016 at 9:49 AM
    #193
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If that becomes a tangibilty, droves of people will buy the brake kits.
  14. Dec 8, 2016 at 10:02 AM
    #194
    Biscuits
    I apologize if this was previously discussed, but what are the advantages/disadvantages of a two-piece rotor?
  15. Dec 8, 2016 at 10:47 AM
    #195
    Iggy
    Northern CA
    Check out the build
    For our application it's mostly a disadvantage. A two piece rotor would be more expensive and also more expensive to maintain.
    They do offer the non TRD branded 4 piston kit that fits 16" wheels.
  16. Dec 8, 2016 at 11:23 AM
    #196
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    It was the Stoptech brake pads. I'm not sure which version it is. I did bed the pads in real good and very aggressively. I installed speed bleeders when I did the calipers and I wasted a lot of fluid. There fluid was nice and clear and no air was left that I could see.
    If I compared them to the stock calipers and pads, it would be a big improvement. However, since I was already running aggressive pads and quality rotors, the jump in performance wasn't much more. I do know that they'll fade less when I'm hard on them so that's a plus.
  17. Dec 20, 2016 at 11:02 AM
    #197
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    ^ Good to know as I was on the fence on these. I have upgraded Rotors & Pads and they do a decent job for daily driving with weekend adventures. I was looking for an upgrade with these or the Lexus brake swap route. I don't tow anything really and to drop this much coin just for the bling factor is not going to cut it for me. I don't have that much additional weight that warrants this upgrade like some of the overland guys.
    Great deal indeed though.
    Good Review as I upgraded to 17" rims to figure out a new brake upgrade.
  18. Dec 20, 2016 at 11:08 AM
    #198
    Iggy
    Northern CA
    Check out the build
    I agree with @SCSPerformance that the initial bite is less than aggressive pads on the stock setup. But I think if you get the same aggressive pad with this this setup you will have a significant braking improvement. Think of the pads that come with the kit as "stock" pads, so you have great power but not the initial aggressive grab that performance pads do. The only draw back with this kit and aggressive pads is getting them to warm up enough to have them be efficient.
  19. Dec 20, 2016 at 11:23 AM
    #199
    RAD
    Rad
    LAX & LOGAN
    ^ Gotcha. . . That makes sense to upgrade the upgrade. We all do it in different aspects of our trucks. I feel this is a great upgrade for those who need it and at the price point as well. Just for me, it's an upgrade that will have to really wow me in order to spend that kind of money.
    I appreciate the insight and real world reviews from people as well. JBerry seems to get the response from the kit as I believe it's the extra weight that assist in providing that stop. I am more set up like Vin and his review is geared more towards me as I have an upgraded set up already. I've had past BBK set ups on other past vehicles and the wow factor is there. I'll dabble more and think it over as I do want to upgrade my brakes.
    Iggy[OP] likes this.
  20. Dec 20, 2016 at 11:33 AM
    #200
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    SCSPerformance and Iggy[OP] like this.
