Stoptech Big Brake Kit Group Buy 2005-2017 Tacoma and Others
Discussion in 'Automotive Group Buys' started by Iggy, Oct 17, 2016.
  1. Dec 20, 2016 at 10:25 PM
    #201
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    GilbertOz and Iggy[OP] like this.
  2. Dec 21, 2016 at 5:12 AM
    #202
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You're welcome.
  3. Dec 21, 2016 at 12:43 PM
    #203
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Is there a set end date for this GB or is it ongoing?
  4. Dec 21, 2016 at 1:16 PM
    #204
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    The code was still active a few days ago.
  5. Dec 21, 2016 at 7:08 PM
    #205
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Yeah. I know the code was still active. Just trying to figure out what the time frame was for how long it will be active. SOS Performance called me tonight because I had put a couple items in the cart and gone part way through the checkout. They said the GB code will be active through the end of the year.
  6. Dec 24, 2016 at 8:06 PM
    #206
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    Got a nice surprise for Christmas.
    126B3908-58D5-42C7-A1E1-30743B3AEB40_zps_261a6191038713c5ac00c7229c3c8a8e030497f5.jpg
  7. Dec 24, 2016 at 8:12 PM
    #207
    DistortedAxis
    DistortedAxis Well-Known Member
    Toronto
    Desert Sand Mica, 2006, V6, 6SPD Manual, SR5, DCSB, 4X4
    STOCK
    Cool, is that the big brake setup or the regular brake kit?
    Anyone running a LT setup with this big brake kit?
    Biscuits likes this.
  8. Dec 24, 2016 at 8:39 PM
    #208
    pngo121
    Phi
    Pittsburg, CA
    BBK. There's a few guys running them with LT on here.
  9. Dec 24, 2016 at 8:46 PM
    #209
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Yes
  10. Jan 4, 2017 at 9:02 PM
    #210
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
  11. Jan 4, 2017 at 9:07 PM
    #211
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
  12. Jan 5, 2017 at 12:49 PM
    #212
    zscott
    Zach
    Utah
    Of course they did. Now the day I ordered new wheels and tires and now that I have had my original BBK for long enough that they probably won't take it back. Oh well.
  13. Jan 5, 2017 at 1:25 PM
    #213
    Iggy
    Northern CA
    Check out the build
    I think you're good with the other kit unless you got drilled rotors. This new kit only comes with drilled rotors.
  14. Jan 5, 2017 at 1:55 PM
    #214
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yours has more mechanical advantage. :thumbsup:
  15. Jan 5, 2017 at 3:04 PM
    #215
    zscott
    Zach
    Utah
    Do the larger rotors make that much difference? The ones on the kit for 17" wheels are what like 340MM vs the 323MM on the kit that fits 16".
  16. Jan 5, 2017 at 3:29 PM
    #216
    Iggy
    Northern CA
    Check out the build
    It might not be as noticeable of a difference. But you're limited to drilled rotors only and they are more expensive rotors to replace later.
  17. Jan 5, 2017 at 4:29 PM
    #217
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    More heat capacity = more fad resistance. Also larger area means more pad material can be used in that surface area.
    Lord Helmet, Torspd and jberry813 like this.
  18. Jan 5, 2017 at 6:00 PM
    #218
    Iggy
    Northern CA
    Check out the build
    But if you don't want to go 17's, then there's the 16" kit.
  19. Jan 14, 2017 at 12:23 AM
    #219
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Code still works. Just ordered a set in black/slotted. Even though I need another 4Runner, I couldn't resist.
    sytfu510 likes this.
  20. Jan 14, 2017 at 12:31 PM
    #220
    Kelvin
    Kelvin Wheeeeee
    Already have a shipping confirmation :playball:
    stairgod likes this.
