Stoptech Big Brake Kit Group Buy 2005-2017 Tacoma and Others
Discussion in 'Automotive Group Buys' started by Iggy, Oct 17, 2016.
  1. May 28, 2018 at 7:11 PM
    #361
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    Yes. They have a regular non branded stop tech rear disk conversion. No need for rear bbk Bc it will only cause your rear end to grip and turn the vehicle sideways. The proportion valve in our trucks is modern and automatic. My older Classics have a proportion valve that governs how much hydraulic pressure is distributed to the rear.
    617mike9c1 likes this.
  2. May 29, 2018 at 4:59 AM
    #362
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is false. Even further down the innacurate spectrum, if the master cylinder is left stock. Since it doesn't apply as much force to a drum setup. This is why SOS Performance offers the master cylinder upgrade, to have the proper pressure applied to the rear.
  3. May 29, 2018 at 5:31 AM
    #363
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Agree. The good thing is the disc brake conversion with the stock master is still a big improvement over the drums. I’m considering the larger master now and how loosing VSC will affect other systems in the truck. My main concern is whether it will create a code that will cause me to fail an inspection.
    Pcyc likes this.
  4. May 29, 2018 at 6:27 AM
    #364
    Shepherd12
    Shepherd12 Well-Known Member
    Josh
    PA Wilds
    Black ‘18 Pro MT
    KO2’s
    Why does upgrading your master cylinder cause you to lose VSC? Anyone have a link explaining this phenomenon?
  5. May 29, 2018 at 8:11 AM
    #365
    Pcyc
    Fritz
    Concord, CA
    See below
  6. May 29, 2018 at 8:23 AM
    #366
    Pcyc
    Fritz
    Concord, CA
    I disagree as you are claiming my statement is false. Not sure you read what i posted but i answered the posted question. We can run our stock master cylinder with a rear disc conversion. Now i agree the “upgrade” to the tundra master is probably the better solution for a rear disk brake conversion as it moves more fluid. The question i answered was about a rear big brake kit. My point was that a bbk (big brake kit) is not nessecarily needed for the rear. Regular disk brakes are fine. Now to my second point often when you covert drums to disk a proportion valve is required. In the Tacoma the master cylinder is capable to operate the conversion with out the tundra master cylinder upgrade. Again the “tundra master cylinder upgrade” is probably better for the swap and worth the money to do so.
    Here is the rear disk i would do. Onto the rear. In my opinion the rear BBK is a waste of money. It adds $1000 but will look way cooler if it’s a show truck etc.
    https://sosperformance.com/products...-with-parking-brake-slash-tr-dot-ps2-dot-ta16
    Here is another link. I was hinting at rear wheel lock up. That probably won’t happen with our abs system. But still just pointing out that it’s not on the “inaccurate spectrum”
    https://www.google.com/amp/s/techta...things-to-know-about-brake-valves?hs_amp=true
    Caboose117 likes this.
  7. May 29, 2018 at 9:02 AM
    #367
    Hawk373
    2012 TRD Sport DCLB
    The problem with this argument is it has nothing to do with the original question. He wanted to match a rear BBK with a front BBK and ensure the rear kit would fit in a 16” wheel. Not run it solo.
    Torspd likes this.
  8. May 29, 2018 at 9:07 AM
    #368
    Hawk373
    2012 TRD Sport DCLB
    The sequoia master cylinder used isn’t VSC capable. I asked Tom if he knew of one that would work and he told me I’d have to experiment with something like an FJ master, but he had no legwork as of yet.
    Shepherd12[QUOTED], Torspd and Pcyc like this.
  9. May 29, 2018 at 9:19 AM
    #369
    Pcyc
    Fritz
    Concord, CA
    Fair i went off the reservation. I still think a bbk for the rear is silly.
  10. May 29, 2018 at 9:24 AM
    #370
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    True, it could be "silly" for some. It all just comes down to the application's necessity.
    Lucario Runner and Hawk373 like this.
  11. May 29, 2018 at 9:30 AM
    #371
    Hawk373
    2012 TRD Sport DCLB
    I’d like both to be in my future, but my feeling is it’s unlikely the front calipers will clear LSK fabbed spindles and I’ll leave things be.
  12. May 29, 2018 at 9:37 AM
    #372
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There has to be some people that have a BBK and upgraded spindles. Has to be...
    Hawk373[QUOTED] likes this.
  13. May 29, 2018 at 9:46 AM
    #373
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I have a gusseted spindle (not fully fabricated) and they clear fine. I talk with Tom quite a bit and I know the 6 piston kit that requires 17” wheels will not clear Fabtech spindles (drop bracket lift). No idea about LSK though.
    Torspd and Hawk373 like this.
  14. May 29, 2018 at 9:48 AM
    #374
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Build to suit your needs. Simple as that. My truck is 6300 pounds loaded up for camping/wheeling weekend. And that’s without my trailer hooked up. Brake fade sucks.
    Anderson, Torspd and Hawk373 like this.
  15. May 29, 2018 at 9:55 AM
    #375
    Hawk373
    2012 TRD Sport DCLB
    As it is, sometimes the stock calipers need a little clearancing for the LSK spindles depending on the particular casting. We’ll see, I’m still waiting on my shocks for install.
    I’d even be willing to stop by SOS for a little R&D. It’s not too far of a hike for me.
    Torspd[QUOTED] likes this.
  16. May 29, 2018 at 10:01 AM
    #376
    Shepherd12
    Josh
    PA Wilds
    Black ‘18 Pro MT
    KO2’s
    I bought my truck with hooliganism being the primary intended purpose. Silly works just fine for me, as long as it performs well and looks good.
    I have to wonder if upgrading the MC is worth losing VSC. Does this affect any other systems? ABS or A-TRAC?
    Pcyc[QUOTED] and Torspd like this.
  17. May 29, 2018 at 10:07 AM
    #377
    Hawk373
    2012 TRD Sport DCLB
    I really don’t want the VSC. I find it to be more of a handicap than a help. I just need to pass inspection when they plug the OBDII reader in.
  18. May 29, 2018 at 10:22 AM
    #378
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    On Tom’s website it says not compatible with VSC but it’s a bit of a misnomer. As long as your master only has 2 wires (for the low fluid level) running to it, you can swap masters. If you have a-trac, the master has like 8 wires. Those are the ones that not compatible.
    For the record I have a 2012 sport which has auto lsd, traction control, and VSC. Only a 2 wire master. All systems work with the sequoia master.
    TacoEspecial, Anderson, Pcyc and 2 others like this.
  19. May 29, 2018 at 10:26 AM
    #379
    Hawk373
    2012 TRD Sport DCLB
    Cool. Sounds like we have the same truck. Not sure what A Trac is so I’m going to guess I don’t have that.
  20. May 29, 2018 at 10:30 AM
    #380
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It’s the Michael J Fox edition tacoma. If you don’t have this button, you don’t have a-trac.
    Pcyc and Hawk373[QUOTED] like this.
