Stoptech Big Brake Kit Group Buy 2005-2017 Tacoma and Others
Discussion in 'Automotive Group Buys' started by Iggy, Oct 17, 2016.
  1. Jul 2, 2018 at 9:43 AM
    #401
    dylmatik
    dylmatik Well-Known Member
    Dylan
    16 DCLBTRDOR
    The 20% off, GB discount only applies to front big brake kits and has been active for some time now. Tom at SOS Concepts recommends doing the front big brake kit before converting the rear drums to a brake system.
  2. Jul 2, 2018 at 10:09 AM
    #402
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
  3. Jul 2, 2018 at 11:34 AM
    #403
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I don't have A-trac, but the ABS system is unaffected. So A-trac should still work.
  4. Jul 2, 2018 at 11:40 AM
    #404
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Also applies to the REAR BB kit..
    617mike9c1 likes this.
  5. Jul 2, 2018 at 12:12 PM
    #405
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Oh so tempting! Guess I better start working my second job again.
    stairgod likes this.
  6. Jul 6, 2018 at 6:22 PM
    #406
    18TrdPro
    18TrdPro Well-Known Member
    Hey all,
    Does anyone have the TR.323.6TA SOS PERFORMANCE 6 PISTON FRONT BIG BRAKE KIT fits Tacoma 6 Lug w/ 16" wheels? I just got a tacoma, coming from an evo, and the brakes are shit, especially for such a heavy vehicle. I see that the coupon code is still active making the kit $1600 instead of $2000. Would this be a good first upgrade to the truck for better braking? I've only had the tacoma a month and I've already had more close calls than I've had in a long time.
  7. Jul 6, 2018 at 10:52 PM
    #407
    000doodie000
    000doodie000 Well-Known Member
    J
    2015 Taco TRD Off-Road
    Many and always modding Wheels Suspension lift Armor Electrical gadgets etc...
    Which one is the TRD rotor? (Link looks dead) and do they make it for a 17 inch wheel?
  8. Jul 7, 2018 at 3:30 PM
    #408
    jojotoo
    Brandon
    Socal
    2015 DCLB
    345mm ? Didn’t think they made them ..
    I have the 340mm 6 pistons front BBKs .. they fit my 17s.
    Hayrider[QUOTED] and jberry813 like this.
  9. Jul 9, 2018 at 12:39 AM
    #409
    18TrdPro
    I just bought the 323 front brake kit for the 16'' stock TRD Pro wheels. Will it be a good improvement over the stock brakes?
    Hayrider likes this.
  10. Jul 14, 2018 at 11:05 PM
    #410
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    I really want to pull the trigger on this deal since it's still active and I need new brakes anyhow.
    What are most people getting as far as Smooth, Drilled, or Slotted rotors?
    I live in CO and go to and from the mountains a lot, so the brakes definitely get a workout. I'll be getting TR.323.6TA and probably the rear conversion, too.
    Also, are the front ss brake lines stock length? I'll be lifting it next and was planning on getting extended lines.
  11. Jul 15, 2018 at 6:11 AM
    #411
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I have drilled and slotted. Should have gotten smooth. Mud gets in everything.
    Unless you have an LT kit the supplied brake lines are fine. You do NOT need extended lines with a "lift".
  12. Jul 15, 2018 at 3:43 PM
    #412
    scootter82
    Aurora, CO
    Pulled the trigger on them. Got the 323mm smooth rotors w/ red calipers. Should look nice on the Baja and compliment the supercharger quite well!
    BassAckwards, jojotoo and stairgod like this.
  13. Jul 15, 2018 at 3:44 PM
    #413
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Go fast means help stopping fast
    BassAckwards likes this.
  14. Jul 16, 2018 at 2:38 PM
    #414
    scootter82
    Aurora, CO
    Anyone know if there will be a 323mm 6-piston caliper rear conversion set? I only see 341mm for the rear.
  15. Jul 20, 2018 at 6:13 AM
    #415
    Bwthomas77
    Bwthomas77 Well-Known Member
    North Carolina
    12 dbl cab trd sport 6spd
    Supercharger, flowmaster exhaust, 4runner disc brakes, Volant CAI, ECGS bushing
    Just found out this product existed, now it has become a huge want.
    Had a close call recently while towing, braking normally is a little weak but with the smoker in tow it is kind of scary.
    What are those that are doing the conversion that requires 17" wheels doing about the spare? I still have stock spare with XD wheels all around.
  16. Jul 20, 2018 at 9:57 AM
    #416
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    You could just rotate a rear tire up front until you get a matching spare.
  17. Jul 20, 2018 at 11:06 AM
    #417
    Bwthomas77
    North Carolina
    Brilliant - not sure why I hadn't thought of that. Thanks.
    Hawk373 likes this.
  18. Jul 21, 2018 at 3:49 PM
    #418
    scootter82
    Aurora, CO
    Regarding trimming the dust cover or installing the hub shim, what are people doing? I have everything apart and am stuck here. The included instructions are ok, but not very detailed. It just says to trim whatever is hitting the rotor, or install shim and tighten bolt to factory specs (which would be?).
    I've bent the dust cover back some, and mocked up the rotor, and it does still run in places. Honestly, it seems I could trim the entire dust cover and it might still rub.
    So what's everyone else done?
  19. Jul 21, 2018 at 4:26 PM
    #419
    jojotoo
    Brandon
    Socal
    2015 DCLB
    I tossed mine .. I think 4Runner covers are a direct fit. Will eventually add sometime in the near future.
  20. Jul 21, 2018 at 6:00 PM
    #420
    scootter82
    Aurora, CO
    Thanks. I figured it out. I didn't fully understand the instructions. But I've chopped the dust cover to hell, and the rotor spins freely now. I'll be ordering the 4runner dust covers and will install those at a later date.
    Toyota 4-runner Dust Covers (ToyotaPartsDeal.com)
    part#s 47781-60120 & 47782-60120 $62.16 EA
    jameskhana and jojotoo like this.
