Stoptech Big Brake Kit Group Buy 2005-2017 Tacoma and Others
Discussion in 'Automotive Group Buys' started by Iggy, Oct 17, 2016.
  1. May 16, 2019 at 12:46 PM
    #501
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    When they made the order for the lines, it is to replace the whole piece since our LT kits use the stock caliper fitting...with the extended lines they wont be compatible with the provided LT ones so thats why they provide a custom long one to replace the bottom two sections of the brake line. Or atleast mine did...maybe they did a better rendition since then.
  2. May 18, 2019 at 3:37 PM
    #502
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    sd1uh8as[QUOTED] likes this.
  3. May 18, 2019 at 5:51 PM
    #503
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
  4. May 24, 2019 at 6:02 PM
    #504
    alexplb
    alexplb Well-Known Member
    I'm guessing that a long grate with lots of weight would heat them up just as much or more as racing... probably still would benefit from having a two piece but my concern is durability with those.... more bolts to worry about :)
  5. May 26, 2019 at 8:44 PM
    #505
    alexplb
    Have you guys that got the TR 323.6TA kit gone trough trouble weighting the rotor? That sucker is around 24-25lbs I hear just wanted to confirm your findings. Trying to decide if I want to go with Wilwood instead that supposedly has a very light set up offered and is about same price point as stop tech, only issue is I'd have to loose my 16" wheels ;...
    kingk0ng likes this.
  6. Jun 11, 2019 at 9:52 PM
    #506
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    Thinking of going wilwood too. The one on gb I think let’s you use stock 4 runner rotors.
  7. Jun 27, 2019 at 9:49 AM
    #507
    alexplb
    Toynado, TacoJova, rodneyrdm and 3 others like this.
  8. Jun 27, 2019 at 10:01 AM
    #508
    kingk0ng
    11 TRD OR AC
    just a few things.
    Nice thats with -0? Will it work for -20?
  9. Jun 27, 2019 at 10:17 AM
    #509
    alexplb
    This is 0 offset I’m guessing it would since -20 is even more space ?
  10. May 9, 2020 at 1:44 PM
    #510
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    What have people been using for the 2nd set of pads on the SOS 340mm tacoma bbk? Stoptech ST-60 caliper.
    My first set of pads are almost gone after only about 20k miles. Looking for something that has more pad life
  11. May 9, 2020 at 2:05 PM
    #511
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Cannot comment on life, but the StopTech Sport pads stop significantly better than their Street pads. Sports likely have shorter life though.
    SUMOTNK[QUOTED] likes this.
  12. May 9, 2020 at 3:46 PM
    #512
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I just swapped mine out for some sport pads. The old ones were pretty low.
  13. May 9, 2020 at 3:57 PM
    #513
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Carbotech 1521
    ETALATE and SUMOTNK like this.
  14. Oct 3, 2020 at 12:57 PM
    #514
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    I’m an idiot. I fully knew about the group buy and when I ordered my kit last week I completely forgot. Anyone know if they will still do it even after I bought it?
  15. Oct 3, 2020 at 1:01 PM
    #515
    TacoJova
    Central Oregon
    And the Stoptech ST-60’s are the same with the 323 kit and the 340 right? Asking for brake pad options when the time comes
  16. Oct 3, 2020 at 1:03 PM
    #516
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Looks like you just missed it by 4 yrs.
    whatstcp likes this.
  17. Oct 3, 2020 at 1:04 PM
    #517
    TacoJova
    Central Oregon
    After my experience with a wilwood setup on a Ram 3500 that was 6 piston front and rear I wouldn’t do that again. I’m waiting on my Stoptech kit to show up to compare them. I do have a AP Racing Kit for my M3 so I have an understanding on what a good setup is
    kingk0ng[QUOTED] likes this.
  18. Oct 3, 2020 at 1:06 PM
    #518
    TacoJova
    Central Oregon
    I thought the code didn’t expire
  19. Oct 3, 2020 at 1:06 PM
    #519
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Then it's a coupon code, not a group buy. Call SOS and ask them.
    SUMOTNK likes this.
  20. Oct 3, 2020 at 4:26 PM
    #520
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    still works for certain items.
