Stoptech Big Brake Kit Group Buy 2005-2017 Tacoma and Others
Discussion in 'Automotive Group Buys' started by Iggy, Oct 17, 2016.
  1. Oct 24, 2022 at 4:36 PM
    #641
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    big money but damn good deal for the complete setup
  2. Nov 4, 2022 at 1:09 PM
    #642
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    @nudavinci64 , how's your ebrake?
    I have the same front BBK and rotors as you and like them.
  3. Nov 5, 2022 at 12:10 AM
    #643
    nudavinci64
    Robert
    Pretty useless but I need to pull it out and adjust. Rebled the brakes this week and one rear rotor is as def not adjusted right as I could pull it off easy. I’m going to give it an adjustment and tighten the cable length. but yah that’s the only part that’s not great. I know another guy who swapped a new d60 axle and hasn’t had any issues.
    TacoEspecial[QUOTED] likes this.
  4. Nov 5, 2022 at 1:54 PM
    #644
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    When @Lucario Runner and I did his rear swap, his emergency brakes worked just fine. He can add if they still do.
    I had a much earlier kit, and they need to be upgraded to his newer version. It would really help.
  5. Nov 5, 2022 at 3:17 PM
    #645
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    My ebrake has been good. Used it towing some heavy equipment to my other property to load and unload the trailer.
    TacoEspecial likes this.
  6. Nov 5, 2022 at 7:34 PM
    #646
    nudavinci64
    Robert
    Yah I wonder if it was just installed wrong. I didn’t have time and had someone else do it. when I pulled off the rear wheels this past week one rotor was loose pads in the drum def were not adjusted correctly. My other assumption is the cable was not adjusted. I’m going to pull calipers off and adjust them and see if it helps. for now the e brake has become a luxury item.
  7. Nov 5, 2022 at 7:52 PM
    #647
    Lucario Runner
    Robert
    06 Toyota 4Runner
    https://www.tacomaworld.com/threads...ily-driver-build.526623/page-22#post-23183007
    might help.
  8. Dec 11, 2022 at 8:13 PM
    #648
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    I'm going to give these a try when I put my new rear axle in early next year.
    AY_ARONTRD, Hayrider and nudavinci64 like this.
  9. Dec 11, 2022 at 10:23 PM
    #649
    nudavinci64
    Robert
    which axle are you going with? a new rear is goin going to be a must. not sure what I want to get yet.
  10. Dec 12, 2022 at 10:42 AM
    #650
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    ECGS Dana 60 with 40 spline axles :D
    :benchpress:
    nudavinci64[QUOTED] likes this.
  11. Dec 12, 2022 at 11:14 AM
    #651
    nudavinci64
    Robert
    Nice! The ECGS 60 is a possible one. Heavy axles but hard to beat the price for almost plug and play.
  12. May 2, 2023 at 3:30 AM
    #652
    SilverSurfer
    SilverSurfer Well-Known Member
    Mark
    Los Angeles
    2013 4X4 LT
    Curious, what length brake lines did you go? I see a few options, just wondering with the TC kit what length.
    kingk0ng likes this.
  13. May 2, 2023 at 10:14 AM
    #653
    nudavinci64
    Robert
    Pretty sure we went with the longer ones. I had both but ordered the longer ones. I think with that you can run from caliper all the way up to the frame.
    SilverSurfer[QUOTED] likes this.
  14. May 23, 2023 at 7:16 AM
    #654
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    Finally ready to pull the trigger on this kit but I see the GB code is only good for 10% now. Does anyone have any newer discount codes?
  15. Feb 3, 2024 at 4:33 PM
    #655
    Chapman
    Chapman Well-Known Member
    Bay Area, CA
    2013 SW DCLB TRD Sport 4x4
    Bumping this thread out of hibernation.
    How many miles are you guys getting out of your front BBK pads? Did anyone also change their rotors? I understand everyone's number is different because of truck weight and their braking habits.
    My rear drums are giving the death screech at 60k so it made me curious how long the fronts last for people.
  16. Feb 4, 2024 at 11:06 AM
    #656
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    I have 20k mi on my front and looks like I can go 15k-20k mi more.
    Only have 5k on the rear stoptechs.
    I weigh close to 6000#.
    I have my original drums with 45k mi on them if you want them.
    I need to get rid of them.
    Chapman likes this.
  17. Feb 4, 2024 at 11:08 AM
    #657
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Would you go with the 17" or 16" setup?
  18. Feb 4, 2024 at 11:12 AM
    #658
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    This thread always gets my attention. Might finally purchase once my current OEM brakes are done. I’ll be needing rotors and pads so might as well. :notsure: It’s between this and stoptech rotors w/trd pads
    Chapman likes this.
  19. Feb 7, 2024 at 12:50 PM
    #659
    Chapman
    Bay Area, CA
    Nice, good to know. How do the brakes feel with the rear Stoptechs? Is it night and day difference vs the drums? I'm a little over 6000#.
    I know little about drums but I think mine should last a few more years, just got to change the shoes. If it craps out sooner I'll definitely reach out if you have it then. Thanks for the offer.
    I went with 17" in the front. If I do the rear, would probably do 17" if it's an option. What did you go with?
  20. Feb 8, 2024 at 7:59 AM
    #660
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Adding the StopTechs in the front was a night and day difference.
    I'm so happy with my braking now especially when I'm loaded up for a big trip.
    I have TRD which has the the electronic boosted master cylinder which makes them work perfect.
    Didn't really notice a change in braking when I added the rear StopTechs but I did start running 37s at the same time.
    I went to a Dana 60 from ECGS and decided to but in new brakes and went with the StopTechs.
    I originally went with the 16" kit but then went long travel and my kit required a 17" rotor so I upgraded.
    Now I have a set of StopTech 16" two piece rotors setting around.
    Chapman[QUOTED] likes this.
