Stoptech Big Brake Kit Group Buy 2005-2017 Tacoma and Others
Discussion in 'Automotive Group Buys' started by Iggy, Oct 17, 2016.
  1. Oct 20, 2016 at 8:55 AM
    #61
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Thanks man! The ramen will taste super stop tech tasty.
  2. Oct 20, 2016 at 9:49 AM
    #62
    TonyDobbs
    TonyDobbs Well-Known Member
    Tony
    Cotati, CA
    2012 LT TRD OR + 2007 TRD Sport
    Ah, yea those won't fit most likely. The 17" TRD Beadlocks will though.
  3. Oct 20, 2016 at 9:56 AM
    #63
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    That is true, I could get those...I wish they made them in black!
    Coot
  4. Oct 20, 2016 at 10:20 AM
    #64
    invidious
    invidious Well-Known Member
    San Antonio, TX
    These brakes are very tempting :ohsnap:
    Coot83 likes this.
  5. Oct 20, 2016 at 10:28 AM
    #65
    dark vader trd pro
    dark vader trd pro Well-Known Member
    William
    NY
    2015 Tacoma Trd Pro
    I basically combine breakfast, lunch and dinner into 1 meal
    sytfu510[QUOTED] likes this.
  6. Oct 20, 2016 at 10:29 AM
    #66
    dark vader trd pro
    William
    NY
    2015 Tacoma Trd Pro
    They do made them in black
    Iggy[OP] likes this.
  7. Oct 20, 2016 at 10:30 AM
    #67
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I have only come across the TRD 17 inch wheels with beadlocks in polished aluminum. If you got a link for some black ones I would be very interested!
    Coot
  8. Oct 20, 2016 at 10:37 AM
    #68
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    @Torspd is in the process of rear disco conversion.
    Torspd likes this.
  9. Oct 20, 2016 at 10:39 AM
    #69
    dark vader trd pro
    William
    NY
    2015 Tacoma Trd Pro
    Sorry I thought u were talking about the caliper
  10. Oct 20, 2016 at 10:39 AM
    #70
    Iggy
    Northern CA
    Check out the build
    For off road applications solid rotors are best, for on-road and race I prefer slotted.
    The 20% off code is active now! The code is on the OP.
  11. Oct 20, 2016 at 10:40 AM
    #71
    dark vader trd pro
    William
    NY
    2015 Tacoma Trd Pro
    Complete with disco ball?
  12. Oct 20, 2016 at 10:46 AM
    #72
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Aw bummer man I was hoping you found one! Its all good...probably get those wheels eventually although suspension is high on my list at the moment.
    Coot
  13. Oct 20, 2016 at 11:00 AM
    #73
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    @IGGY are the rotors larger or the same size as factory?
  14. Oct 20, 2016 at 11:01 AM
    #74
    Coot83
    Scottsdale, Az
    2012 Baja TX
    The garage floor NEEDS these!
    Coot
  15. Oct 20, 2016 at 11:04 AM
    #75
    SonnyBones
    Jeffery
    Lol rear disc conversion
  16. Oct 20, 2016 at 11:38 AM
    #76
    Iggy
    Northern CA
    Check out the build
    Way larger! 340mm
    A few posts back you can see the rotor sitting in my 16" rim.
  17. Oct 20, 2016 at 11:57 AM
    #77
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Ordered :anonymous:
    tacomgee, sytfu510 and Iggy[OP] like this.
  18. Oct 20, 2016 at 12:16 PM
    #78
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I'm here for the Gang Bang
    I was told there would be cookies
  19. Oct 20, 2016 at 12:32 PM
    #79
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have a 6 piston big brake kit. But not StopTech. :pout: either way, that kid has upgradable components to appease your desires as well as will be a major Improvement in breaking.
    Mike it was also ordered through SOS performance, Pryor to them carrying the stoptech big brake kit of 6 Pistons.
  20. Oct 20, 2016 at 1:14 PM
    #80
    dark vader trd pro
    William
    NY
    2015 Tacoma Trd Pro
