Stoptech Big Brake Kit Group Buy 2005-2017 Tacoma and Others
Discussion in 'Automotive Group Buys' started by Iggy, Oct 17, 2016.
  1. Oct 21, 2016 at 8:21 PM
    #101
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I don't know, but if it's slow I would assume we hit 6 and it's gone.
  2. Oct 22, 2016 at 3:09 AM
    #102
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I need to do my brakes anyway, so why not upgrade at the same time right? I can justify this as a need.
  3. Oct 25, 2016 at 10:30 AM
    #103
    alvinfromhawaii
    alvinfromhawaii Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    Placed my order. Thanks for setting this up.
    Iggy[OP] likes this.
  4. Oct 25, 2016 at 11:11 AM
    #104
    Iggy
    Northern CA
    Check out the build
    Thank you!
    Anyone else who ordered, please let me know so I can keep track.
  5. Oct 25, 2016 at 11:17 AM
    #105
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @DOUBLLD
    You're going to need these. ;)
  6. Oct 25, 2016 at 11:18 AM
    #106
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  7. Oct 25, 2016 at 11:22 AM
    #107
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    lol i plan on buying them just dont have the money right now have a million things goin on with the truck. a ton of powder coat mainly
  8. Oct 26, 2016 at 1:22 PM
    #108
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Hmmm....I'm leaning towards the st40 trophy with a 2 piece rotor. Haven't looked at savings on pads with the st40 vs st60, however st40 pads (carbotech) are cheaper than buying for the oem calipers. St40 calipers should also be lighter and maybe more rigid, but I was looking at apracing calipers due to them being even lighter do to their material. Don't know just need to focus on the K5 for now, damn the savings are temping.
  9. Oct 26, 2016 at 1:52 PM
    #109
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    also does anyone know the difference between the two sets they offer for the 6 piston kit? two piece rotor verse once piece?
  10. Oct 26, 2016 at 2:17 PM
    #110
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    Arrived today:
  11. Oct 26, 2016 at 2:32 PM
    #111
    sytfu510
    Alex
    Bay Area
  12. Oct 26, 2016 at 3:44 PM
    #112
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Two separate the heat as much as possible, between the hat and the rotor. The rotor will have heat expansion slots, bolted to the hat with inconel hardware.
    One piece does not have this ability.
    Race car tech.
    DOUBLLD[QUOTED] likes this.
  13. Oct 26, 2016 at 7:04 PM
    #113
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Ordered. I quiver with anticipation!
  14. Oct 27, 2016 at 3:34 AM
    #114
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Since I'm not really racing and abusing them like you would.... lol you think I could get away with the one piece?
  15. Oct 27, 2016 at 5:11 AM
    #115
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Any idea if these will fit under the 17 TRD Pro wheels?
  16. Oct 27, 2016 at 5:48 AM
    #116
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You could get away with the solid rotors just fine. Upgrade later if so inclined.
  17. Oct 28, 2016 at 2:42 AM
    #117
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Yes
  18. Oct 28, 2016 at 4:26 AM
    #118
    Kennedyusmc
    Christopher
    2017 Cement Pro
    You sure? The 2017 Pro wheels are 16s- ?
  19. Oct 28, 2016 at 4:38 AM
    #119
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Oops. I read that as 17" Pro wheel. I would call them and see if those calipers fit under 16" wheels. The larger list specifies 17" wheels, but this kit does not.
  20. Oct 28, 2016 at 4:41 AM
    #120
    Kennedyusmc
    Christopher
    2017 Cement Pro
    Yeah thanks- sorry for the confusion. I read above they will fit under the TRD beadlocks which are 16- so there's hope. If they fit I'm in.
    stairgod[QUOTED] likes this.
