Storage Chest
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Jan 6, 2012.
  1. Jan 6, 2012 at 10:28 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello Forum,
    I just ordered a storage box in black: 32W x 12.5H x 12D. I want to bolt it to the bed but be able to remove it easily when necessary. In other words, I would like to permanently bolt on 2 brackets which the box will then be bolted to that. Anyone out there familiar with this or have any ideas? Please provide pics if possible!
    Thanks!
  2. Jan 6, 2012 at 10:41 PM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    you could use some metal or aluminum and install wing nuts instead of nuts .it would be easier to take out??????:rolleyes:
  3. Jan 8, 2012 at 3:34 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Thats a good idea about the wing nuts but does anyone know where I could buy two brackets which I could bolt through the floor and that the brackets have bolts facing up also for me to attach the box to?
  4. Jan 8, 2012 at 3:40 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Lowe's or HD will have some angle material. use a hack saw to cut to desired length.
