Storage compartments in bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbp68, Nov 24, 2009.
  1. Nov 24, 2009 at 3:36 PM
    kbp68
    kbp68 [OP] hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    The doors on my storage compartments will not stay closed. They fall open almost as soon as I get on the highway. I have tried tightening the philips screw on the latch mechanism but it seems flimsy and I don't want to overtighten it and bust it. Searched this site but can't find anything. WTF am I the only one? I keep checking the rearveiw and expecting to see that little door flying out onto the freeway!:eek:
  2. Nov 24, 2009 at 3:49 PM
    bryant8
    bryant8 Active Member
    Dallas
    2008 Black Double Cab Long Bed
    TRD CAI, eBay Fog lamps, LED bed lights, 12V bed plug
    sounds like the tabs are loose when they are in the closed position, I'd just bend them a slight bit toward the covers so they bite into the slot a bit more
  3. Nov 24, 2009 at 3:53 PM
    Fore
    Fore Well-Known Member
    07 PreRunner
    Replace them with cabinet locks from your local hardware store, about $5 for each. Do a search and you should come up with the DIY mod that shows you how to do it. It's pretty easy.
  4. Nov 24, 2009 at 4:21 PM
    Caduceus
    Caduceus Well-Known Member
    the Lowcountry
    09 DCSB TRD 4x4
    Just don't forget to squirt some WD-40 in there every once in a while. I looked like a schmuck when 1 of the 2 locks stayed locked and I couldn't easily get to my tie-downs.
  5. Nov 24, 2009 at 6:55 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    The two tabs on the cover that drop into the slots in the bed might have broken off.
  6. Nov 24, 2009 at 7:08 PM
    kbp68
    B.C.
    TRD Off Road DC/SB
    Thanks guys but I don't really need or want to lock them. I just don't want to have to worry about them blowing out of the truck. I'll try bending the tabs first.
