storage under the radio & power outlet addition
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, May 22, 2012.
  1. May 22, 2012 at 7:28 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello,
    I have an '08 Prerunner SR5 DC with the 4.0. I only have 2 power outlets in the lower section of the dash. I am interested in installing a 12v power outlet in the little plastic square to the right of the radio & one in the plastic panel behind the center console. Is there a power wire that I can tap to supply power to these 2 outlets & not damage anything or do I have to find a power source in the fuse block under the dash on the drivers side?
    Also, if anyone is running a similiar set up aftermarket radio, do you have any ideas on what to put in that space?
    Thanks:D
    http://i1056.photobucket.com/albums/t379/TACRUN1/Photo1043.jpg
    http://i1056.photobucket.com/albums/t379/TACRUN1/Photo1042.jpg
  2. May 22, 2012 at 7:29 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    you might be able to run off one of the 12v plug wires
  3. May 22, 2012 at 7:31 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    now for the center console you will probably have to run a power wire to it. I dont there is anything down that way
  4. May 23, 2012 at 10:59 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Have you considered tapping off of one of the wires for the existing plugs? :D
