Storing the taco?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MarineTacoDriver, Jul 23, 2010.
  1. Jul 23, 2010 at 9:12 PM
    MarineTacoDriver
    MarineTacoDriver [OP] Well-Known Member
    Brian
    Cherry Point
    09 SR5 4x4
    ARB front bumper, Warn M8000, ATO front/transmission/transfer case skids, Icon ext travel coilovers, Total Chaos UCA's, OME Dakar leaf springs, Bilstein/RCD 5100 3-4" lift shock, extended stainless brake lines, DrewFab shackle flip, rear ARB Airlocker, ARB air compressor
    Headed out for a little while in October, was just wondering what everyones thoughts on storing the truck for a while were...
    1) Gas tank, full or empty? I've heard some people say you want to leave it full, and some say empty, some say it depends on if you have a metal, or plastic tank.
    2) Oil, I should be just about due for an oil change when I leave, should I get the oil changed and have the new stuff sitting in there while I'm gone, or would I be fine leaving the old stuff sitting in there while I'm gone to save some cash? (I run synthetic if that matters)
    3) Tires, I am about to get some new tires, should I put the old ones back on while it is sitting to keep them from getting flat spots?
    4) It is unknown where I am going to be leaving my truck at the moment, may have to put it in storage, may leave it at a friends house. How often should I have someone go out and start it, and should they drive it around as well to get it everything moving around a little? (I knew with my 85' F150, my dad did that while I was at boot camp, and it's probably the only reason it started when I get home)
  2. Jul 23, 2010 at 11:36 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    gas tank, i dont know what the consensus is on that, id leave it at half
    change your oil after, why let it sit, give your truck a treat when you come back
    so that you dont have to worry about tires, put the truck up on blocks, wheels off the ground, so you wont have flat spots on either set...
    just unhook the battery while your gone and keep it on the blocks... it will start right up when you come home and get it off the blocks, change the oil and plug the battery back in...
    anyone who wants to correct me, go ahead, im not sure if this is all correct
  3. Jul 23, 2010 at 11:40 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    fuel stabilizer in the gas tank you dont want varnish
    jack stands if you want to
    and most importantly a trickle charger for the battery.
    usually I keep my tacos in the fridge though
  4. Jul 24, 2010 at 10:04 AM
    MarineTacoDriver
    Brian
    Cherry Point
    09 SR5 4x4
    Unknown at this time, they said 4-7 months. The last guys they told 3-4 months, and they were gone 9 months :rolleyes:
    So fuel stabilizer, disconnect the battery, put it up on jack stands...
  5. Jul 24, 2010 at 12:04 PM
    ktmrider
    Junk
    trickle charger for the battery if you want it to maintain its health
  6. Jul 24, 2010 at 12:28 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
