Straight (not 50/50) mix Toyota or compatible Antifreeze
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jolly Onion, Oct 14, 2016.
  1. Oct 14, 2016 at 8:44 PM
    Jolly Onion
    Jolly Onion [OP] Cheap is not Good & Good is not Cheap
    Alex
    Forest Hills, N.Y
    2004 Tacoma 6cyl crewcab
    Who makes one?
    Thanks
  2. Oct 14, 2016 at 8:58 PM
    Indy
    Indy Master of all I survey.
    The shelves at walmart are full of Antifreeze.
    Mush Mouse likes this.
  3. Oct 14, 2016 at 9:14 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
  4. Oct 14, 2016 at 10:06 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    not 50/50
    And not Antifreeze at Walmart etc.
    Toyota and Zerez European are 50/50.
    Safe to mix and compatible with Toyota.
    My search came up with NOTHING. So just checking
    Thanks
    A
  5. Oct 14, 2016 at 10:09 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    In using the Toyota long life "pink" coolant
  6. Oct 15, 2016 at 2:49 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I am not sure just what your trying to ask
    Most all coolants come in the undiluted or the premixed in your part of the world maybe no one stocks the undiluted because it never sells no one wants to bother mixing there own coolant.
    I just use the Toyota Red and mix it myself
    Just curious why you don`t care for the premixed I think to use for topping off when needed it would work just fine.
    I pretty much mix a few gallons at a time of close to a 50/50 mix
    Now last I bought the price of the premixed is not all that much cheaper so the full strength is a better buy but most often when I need coolant I need it now now a week from Now!!
  7. Oct 15, 2016 at 5:48 AM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Good question.
    Reason for wanting the straight antifreeze is I do not want to drain the distilled water left in the block after flushing few times.
    So by having straight antifreeze, i can mix it myself and compensate for the water left in the block to have the desired mix.
    Thanks
    A
  8. Oct 15, 2016 at 7:48 AM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    You can get full strength antifreeze that is compatible with your truck pretty much anywhere that sells automotive parts and supplies.
    AutoZone, O'Reilly, Napa, walmart, dealership, etc.
  9. Oct 15, 2016 at 7:52 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    xerex/Valvoline Asian 50/50 mix at Walmart
  10. Oct 15, 2016 at 11:08 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    It might not be stocked on that Little Island he lives on.
    Because it does not sell because most people might not even know how to open the hood let alone mix coolant
  11. Oct 15, 2016 at 4:54 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    True
    Not know how to change flat tires as well. I have helped many change flats.
    I found this which is straight, is it compatible for 2004 Tacoma ?
    https://www.amazon.com/Toyota-Genui...qid=1476575601&sr=1-1&keywords=00272-1LLAC-01
  12. Oct 15, 2016 at 4:56 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    The little Island is having less and less MAKERS.
    And more and more TAKERS coming in.
    And the makers are moving on and out when they retire.......as they should.
  13. Oct 16, 2016 at 4:14 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    That is what I use in my 3.4 I looked on the container for the part #
    Either the cost has really gone up because when I bought my last case it was much cheaper
    Then time flies
  14. Oct 16, 2016 at 5:50 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    That's 50/50
  15. Oct 16, 2016 at 9:55 AM
    Indy
    If you're going to try to mix it yourself make sure you get one of the little tester thingies. Max cooling and max freeze protection comes about in the correct ratios. If your ratio is off you'll lose degrees in either direction. To mix it in the truck you'll have to drain as much as you can (assuming you measure what comes out) so you know how much is left and adjust accordingly. If you just dump a bunch of water out you'll need to take your best guess, run it for a while, test it, dump out some more (unless you got lucky) add in either coolant or water depending, run it again for a while, test again etc etc etc.
    Full drain + 50/50 will get you closer faster. But you should be able to eyeball it fairly close.
  16. Oct 16, 2016 at 9:59 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Is it true that you MUST only use pink antifreeze in toyota vehicles?
    Ive seen green antifreeze that says it works for all makes and models...
  17. Oct 16, 2016 at 10:26 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    It does not have to be Red or pink as long as it is suitable for aluminum
    No Silicates they don`t play well with Aluminum water pumps
    There is Green Coolant in my older Toyota Engines
  18. Oct 16, 2016 at 11:07 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Thanks
  19. Oct 16, 2016 at 11:38 AM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Ok guys aim about to do a flush on my 01 v6 i got a 50/50 should i be ok with this ??
    I just got the truck 3 months ago . I think it has a pink fluid now .
  20. Oct 16, 2016 at 1:57 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    What happened that you need to flush the cooling system??
    Coolant never changed from New??
