Straight up... cheap easy way to gain decent horsepower
Discussion in 'Performance and Tuning' started by tac1uscg, Mar 7, 2010.
  1. Mar 7, 2010 at 2:27 PM
    tac1uscg
    tac1uscg [OP] Member
    connecticut
    08 doublecab sport
    OME 3 inch lift, Nitto Terra Grappler tires, Konig Countersteer offroad type x wheels, bed cover, grille guard w/ PIAA lights, Pioneer AVIC-X920BT head unit, Pioneer TS-A6993R front door speakers, JL C2-525x rear door speakers
    CAI...Exhaust...headers.... what is the best way?
  2. Mar 7, 2010 at 2:29 PM
    Brunes
    Brunes abides.
    Rotorhead
    Horsepower isn't ever really cheap. Real gains- Super charger and a good tune...
    Decent gains- Remove excess weight, better air filter, higher flow muffler....All the basics...
  3. Mar 7, 2010 at 2:43 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    $$$=horsepower! effin sucks!
  4. Jun 14, 2010 at 11:29 PM
    quackhead03
    quackhead03 Active Member
    cody
    03 ex. cab
    K&N filter flowmaster exaust w/ chrome tip
    throttle body spacers
  5. Jun 14, 2010 at 11:31 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    lol
  6. Jun 14, 2010 at 11:35 PM
    YeahYeah
    YeahYeah Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
    hey, just curious not relating to the post but tac1... coast guard right? where you stationed?
  7. Jun 15, 2010 at 10:38 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Like someone above said, "wud ya wanna spend"?
    I've summarized the performance upgrades that I am aware of as follows:
    Notes:
    o I have not pulled the trigger on any of these as yet, playing with an air intake mod, swapped in an electric fan, but that's it
    o data is from research I've done, and what I've seen others have done, summary is my own, opinions and order is my own
    o some combinations of mods make sense, others don't, I'm not even going to attempt that list
    o multiple mods are rarely totally cummulative, i.e., CAI+CB+MAF does not equal +15hp ***
    Group 1 ($250-400 each):
    o Aftermarket CAI - 3-5 hp at top end, gain/loss is intake "growl/noise" depending on your stand
    o Cat-back exhaust - 3-5 hp at top end, gain/loss is exhaust note, hard to gauge what sounds good to you personally, may be too loud/droney, or too quiet
    o URD MAF Calibrator - 5 hp +/- - I'm least up on the gains for this one, you'll need to do more research
    Group 2 ($500 +/- each)
    o Headers - 15-20 hp - LT or shorties, decision depends on where you want the power (high-rpm or low rpm) and how much to spend, LTs require O2 sims, shorties require the cats to be welded on
    o Y-pipe - 10 hp ?? - I'm least up-to-speed on the true gains here, need to watch out for an annoying rasp if using the Y-pipe and LTs
    Group 3 ($1300, not supported on 09+ yet)
    o APR X-1 - 20-25hp - complete control over ECU maps, includes exhaust cam gear upgrade, should equate to more power across the rpm band due to tunability
    Group 4 ($3500-5000 depending on who installs)
    o TRD/URD supercharger - 50-60 hp or so - it's an SC, power should come on from off-idle to redline
    Group 0.5 (forgot it earlier... $50-100 each)
    o drop-in air filter (i.e., AFE Pro-Dry) - ?? hp, probably somewhere between 0-1 :)
    o cut in a muffler - 2-3 hp (or -hp depending on muffler), get the CB sound at significantly less cost
    Personally, if I were to pull the trigger right now I would do some combination of Group 2 and 3 depending on funding levels. I don't see the benefit of Group 1, and don't particularly want to invest to the Group 4 level.
