Straighten steering wheel after rack replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Nov 27, 2020.
  1. Nov 27, 2020 at 5:35 AM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    So let's say, hypothetically, I replaced my rack and pinion, and the steering shaft to rack coupler was a real pain in the ***, and in the process, the steering got turned from it's straight position. I THINK it's straight, but I'm worried it may be 360° off. What's the best way to make sure it's straight, without damaging the clock spring?
  2. Nov 27, 2020 at 9:28 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    So, hypothetically you didn't tie off the steering wheel when it was disconnected and the wheel was rotated.
    If it isn't broken I wouldn't worry about it. I don't know of a good way to tell if the spiral cable was centered or not.
    Maybe someone else can tell.
    Muddinfun likes this.
  3. Nov 27, 2020 at 1:47 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    I did tie it off initially, but the coupler wasn't coming off, so I took the seatbelt off to turn it a little bit to get a better angle, with the intention of remembering which way I went. Well....I didn't.
  4. Nov 27, 2020 at 1:55 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Hypothetically. Center the steering wheel. Very slowly go each direction and count rotations. You’ll know.
  5. Nov 27, 2020 at 2:13 PM
    Brian_d
    Brian_d Well-Known Member
    Socal
    Disconnect the coupler again & VERY GENTLY AND SLOWLY turn the wheel each direction and count the turns to find center. You'll be able to feel the clock spring hit its limit - do not force it! I can't over-emphasize going slowly and gently. The only other way to center the clock spring is to remove the steering wheel and center the clock spring by hand. Good luck
    gotoman1969 likes this.
  6. Nov 27, 2020 at 2:15 PM
    gotoman1969
    This ^^^^. Double emphasis on the slow and gently.
  7. Nov 27, 2020 at 2:29 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    Thanks, I think I got it. We will know tomorrow!
