Straighten that front bumper cover? 2000 Taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by Truckrider, Aug 9, 2015.
  1. Aug 9, 2015 at 12:13 PM
    Truckrider
    Truckrider [OP] Your truck is your armor in this world.
    Tony
    Los Angeles CA
    2000 PreRunner 3.4L 2WD
    Been trying to find pics or instructions for removing/re-mounting that front bumper cover so it's straight and flush with the fender. Here's the way it looks now, it's even worse on the other side in this pic? Any thread you can point to, or where the bolts are? Happened with previous owner, just want to tidy her up.
  2. Aug 9, 2015 at 2:43 PM
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Sub'd. I'm having the same exact issue and it bugs me every time I look at it.
  3. Aug 9, 2015 at 2:47 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Super glue and duct tape
  4. Aug 9, 2015 at 8:07 PM
    mhorton1911
    mhorton1911 Fightin' Texas Aggie Class of '19
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    Trail Gear front and rear bumper, 5100's all 4 corners, Eibachs, toytec AAL 1980 Ford pickup horn, and lots of battlescars :)
    Mine used to be like that before i got my TG.
    There are 2 bolts that hold it to the frame on each side, loosen all of em and there is enough wiggle room to scootch it back up where you'll want her, then tighen her up.
    DustStorm4x4 likes this.
  5. Aug 10, 2015 at 1:18 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Is it an aftermarket bumper? Mine looks exactly the same way after i had to replace it after an accident. I was only able to get 3 of the 4 bolt holes to line up. There are white plastic panels that screw into either side to hold the outer edge of the bumper. If these are missing, it will sag.
    http://www.amazon.com/Genuine-Toyot...sim_263_1?ie=UTF8&refRID=0NZMZMVPTW2PNE63MM8G
    Though as mine was aftermarket and ill fitting to begin with, too much pressure was resting on these parts, and caused both to crack. Ive been ignoring it until i can find a used OEM front bumper or can afford a new CAPA certified replacement.
  6. Aug 10, 2015 at 5:45 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    I replaced the two bumper brackets on my truck that were bent just a tad and that made a world of difference. It was back in 2009 so I don't remember much about it although even with brand new OEM bumper brackets it took some time to get it aligned just right. I found this picture from when I was test fitting the new bumper cover I bought for it before I had the cover painted (My truck is a 2003).
  7. Aug 14, 2015 at 5:27 PM
    Truckrider
    Tony
    Los Angeles CA
    Thx for the ideas so far and the parts link. Will try to get somewhere with it over the weekend and put up pics if I make progress or improve it.
