Stranded! Crank but no start, temp gauge acting weird
Discussion in '1st Gen. Tacomas (1995-2004)' started by Canyon Jeff, Jul 11, 2014.
  1. Jul 11, 2014 at 7:19 PM
    Canyon Jeff
    Canyon Jeff [OP] Well-Known Member
    Jeff
    Southeast Utah
    98 Tacoma V6 3.4, TRD 4x4 5-speed 100k miles
    I suddenly have a MAJOR problem with no idea how to fix it. I live in a super remote area with no way of traveling without my truck, so if anyone can please give me some advice, I would really appreciate it!
    DETAILS;
    1998 Tacoma 4x4 V6 3.4 5 speed, 100k miles
    Truck has been running just fine for a long time. I started it about an hour ago with absolutely no problem. I was going to do an oil change, so I started it up and turned the wheels all the way to the left so I could access the oil filter. NO PROBLEM. Turned it off, went in with a rag and cleaned off the dust around the oil filter. Getting ready to change the oil and realized I was a quart short, so decided to hold off. Went to start the truck to move it, and here is what happens now, every time I try to start it:
    will crank, but wont turn over. With foot on clutch pedal and brake, engine temp gauge reads as hot as it can go. If I remove my foot from the brake, the gauge slowly starts to drop (this is while still cranking). It will drop all the way to "cold" in about 15 seconds. NOW GET THIS: when I turn the key off and remove it, the temp gauge shoots back up to "HOT AS HELL", and the check engine light comes on. If i turn the key to ACC. it stays that way, and if I turn to "ON", it drops quickly back to cold and the check engine light goes off.
    What the F#$(&* is that?!
    please for the love of god help me! :eek:
  2. Jul 11, 2014 at 7:21 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Sounds like an electrical problem.
    Check all fuses and electrical connections.
  3. Jul 11, 2014 at 7:22 PM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    Sounds electrical , moving the wheels to far over might have shifted a wire bundle start back tracing from wheel well shake a bundle of wires here and there keep checking the gauge. Or pop the covers off your fuse panels and start checking for hot fuse / relays.
    Cypher
  4. Jul 11, 2014 at 7:22 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Sound like an electrical short somewhere? Maybe the ignition is trying to go bad.
  5. Jul 11, 2014 at 7:25 PM
    Canyon Jeff
    Jeff
    Southeast Utah
    Thanks for the quick replies. I am gonna go back out there and start messing with it (methodically, of course). Keep the advice coming!
  6. Jul 11, 2014 at 7:29 PM
    wee
    wee Well-Known Member
    Might try taking one of the battery cables off....? When it gets dark outside have someone try to crank it and look for sparks....That is also a good way to see if you need new plug wires...If they are arcing replace them.
    Brian
  7. Jul 11, 2014 at 7:46 PM
    Canyon Jeff
    Jeff
    Southeast Utah
    I followed Cypher's advice, and now everything is back to normal. I'm not sure which bundle of wires did the trick, though, because I went thru methodically first and nothing happened, and then I got pissed and just started shaking every wire in sight, and POOF! Problem solved.
    I am fucking done with this day!
    Thanks for all your help!
  8. Jul 11, 2014 at 7:46 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Could you have accidentally disconnected something when you were dusting off the oil filter? Check wires in that area. Like everyone else has said, it seems electrical. Sometimes the quick starts and shutoffs could blow a fuse, not sure why it happens but I've seen it happen. Also, after you check it out try the battery disconnect and let it sit for a good 15 minutes or so to allow the computer reset, then connect it back up and see if it helps.
  9. Jul 11, 2014 at 7:49 PM
    Canyon Jeff
    Jeff
    Southeast Utah
    Yes, Mainmoe, I think it had something to do with dusting off the oil filter. There are quite a few wires in that area, and I was definitely bumping into them. And I don't think turning the wheels had an effect, cuz I can't see how that would have shifted anything.
  10. Jul 11, 2014 at 8:05 PM
    Madjik_Man
    Colorado Front Range
    Glad it worked out.
    Sometimes the Fonzarelli method works best.
  11. Jul 12, 2014 at 7:17 AM
    Mainmoe02
    Moe
    Austin, Texas
    Nice, I'm glad you figured it out and its back to running normal
