Stranded: Ignition cylinder seems jacked
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Mar 26, 2012.
  1. Mar 26, 2012 at 12:54 PM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    So I can't turn my key in the ignition much at all. I can move it just barely enough to unlock the steering wheel but that's it.
    I can't even get it into the ACC position, not even close.
    Has anyone experienced this and is it as simple as having a new cylinder or switch or something replaced?
    FML
  2. Mar 26, 2012 at 12:59 PM
    KCin HBCA
    KCin HBCA Well-Known Member
    Keith
    Huntington Beach
    09 Dbl Cab PreRunner
    Had a similar problem... turn the steering wheel as far as you can to the right... hold and try to turn the key, didn't work? Turn to the left and hold... try now... Mine was parked against a tree root and bound up the wheel lock mechanisim.
    Hope this helps...
  3. Mar 26, 2012 at 1:00 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    My brothers 01 had the same issue. He ended up needing a new tumbler I believe.
  4. Mar 26, 2012 at 1:01 PM
    H Bomb
    H Bomb Well-Known Member
    SAS'd 92 Pickup/08 SR5 Tacoma
    Something similar happened o a buddy of mine. He ended up just needing a new key.
  5. Mar 26, 2012 at 1:01 PM
    Madjik_Man
    Boulder, CO
    My friend's shop is predicting this is the problem.
  6. Mar 26, 2012 at 1:02 PM
    Madjik_Man
    Boulder, CO
    I was wondering about this because my key must be pretty worn out after 14 years.
    I'm hoping that's just the issue.
  7. Mar 26, 2012 at 4:09 PM
    Madjik_Man
    Boulder, CO
    If the spare key works, they can pop the cylinder out and have a locksmith repair it: $60
    If the spare key doesn't move the tumbler, then they need to drill it out, get a new one and re-key it to match the existing keys: $180
    FML
  8. Mar 26, 2012 at 4:15 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    My friend took my old but very clean Chevy S10 from me (I regret it now) and after about a month she told me the key doesn't work. I found the spare and brought it to her and it worked no problem. Ends up the key that I gave her had worn down so bad that it was no where the shape of the spare. Before you get any new tumbler, why don't you try the spare? :)
  9. Mar 26, 2012 at 4:19 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Shot of WD40 into the cylinder and see what happens.
  10. Mar 26, 2012 at 7:24 PM
    Madjik_Man
    Boulder, CO
    Trying that first thing in the morning before we do anything. I have to in fact. Apparently the cylinder won't come out unless the ignition switch is unlocked.
    ramonortiz55 likes this.
  11. Nov 16, 2016 at 2:34 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    How'd you figure this out?
  12. Nov 16, 2016 at 2:50 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    My guess would be that your key chain crap weighs 5 pounds !? Lol
    I only insert the single ign. key... No key ring or 5 lbs hanging.
    and the ignition has held up fine for 16 years.
    Be careful with spraying crap inside the ign. key slot
    'cause if that solidifies or gums up...
    it's going to make matters even worse.
  13. Nov 16, 2016 at 2:56 PM
    PROseur
    PROseur PROBROHOE
    2001 2.7L 4door /2017 6MT PRO /2018 2.7L SR Utility
    Happened to me last month
    Key was totally worn
    Tumblers were jacked
    Needed new one from Toyota plus locksmith install
    Total cost $187
