Stranded in Jacksonville, FL
Discussion in 'Florida' started by LantzB, Aug 29, 2021.
  1. Aug 29, 2021 at 5:19 AM
    LantzB
    LantzB [OP] Member
    Lantz
    2001 Tacoma sr5 6cl manual shift
    I have a 2001 Tacoma sr5 and the differential is bad and grinding I’m stranded and needing to drive home to fix can I remove my front c/v axles and drive it home ? Thanks for accepting me into the group .
    tacotoe likes this.
  2. Aug 29, 2021 at 6:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    More specific please.
    Are you saying the front diff is the problem? Can't get it unlocked?
    If you would include a location (city/state) there may be someone in the area who could assist, if assistance is needed.
    Not really 'technical chat', you'd get more attention the 1st gen forum.
    tacotoe, ColoradoTJ and tcBob like this.
  3. Aug 29, 2021 at 6:39 AM
    0xDEADBEEF
    0xDEADBEEF Trash Aficionado
    2000 reg cab 4x4 flatbed MT
    If you take the cv completely out your wheel will fall off. But I think if you disassemble the cv and leave the end of it bolted in at the wheel side it’ll stay together. Hard part is taking the cv apart to do that.
    @eon_blue might have some other ideas
    LantzB[OP], tcBob and tacotoe like this.
  4. Aug 29, 2021 at 6:43 AM
    LantzB
    LantzB [OP] Member
    Lantz
    My differential output yoke is banging my steering assist and I need to drive 350mikes home can I remove my front c/v axles so I can replace the damaged differential in my shop at home I’m stranded with low funds in Jacksonville, Florida and don’t have equipment Needed for repair ?
  5. Aug 29, 2021 at 6:46 AM
    LantzB
    LantzB [OP] Member
    Lantz
    Thanks
  6. Aug 29, 2021 at 7:40 AM
    LantzB
    LantzB [OP] Member
    Lantz
    I’m thinking now all I need to do is replace the seal on the differential possibly and drive on ?
  7. Aug 29, 2021 at 7:48 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    You can safely remove the front drive shaft (but it doesn't spin unless 4wd is engaged), but not the CV's. Without the splined CV axle shaft and retaining nut in place, the wheel will come off.
    straightawaykid and eon_blue like this.
  8. Aug 29, 2021 at 7:50 AM
    0xDEADBEEF
    Can you post pics? This seems like a really strange problem to have.
  9. Aug 29, 2021 at 8:04 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Like others have said you will need to separate the outer mini shafts from the cv assembly as this piece essentially bolts the knuckle to the hub.
    Might be a good idea to drain the diff as well or find some way to plug the openings.
  10. Aug 29, 2021 at 8:05 AM
    LantzB
    LantzB [OP] Member
    Lantz
    The differential unit output shaft has beat my rack and Pinion steering fluid lines flat , I removed the driveshaft and it bangs worst
  11. Aug 29, 2021 at 4:19 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Your telling me if a cv axle breaks that the wheel falls off?!?!? Mine sure as Hell wouldn’t. People have cut them out with sawsalls for eons if the joint fails on the side of the road. The oil might run out but who cares. Removing the front driveshaft won’t do squat if the front axles are still turning. Cut the friggen thing with a hacksaw and drive it home. You can’t exactly remove it properly on the side of the road or for cheap money. Have someone cut it.
    straightawaykid likes this.
  12. Aug 30, 2021 at 8:35 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Cutting the CV Axleshaft is much different than removing the cv axle assembly altogether... If you cut the axle shaft- the splined part of the cv axle will still run through the hub/bearing, and be held in place by the large nut.
    Back in the day when these trucks were new (and the TTORA community was still running the Delphi-based forum), I witnessed someone break their CV axle on the trail during a group run. They proceeded to remove the remnants of the CV axle from the rig and try to limp home. This ultimately resulted in the wheel falling off. It happened a time or two to other members in the forum before the group consensus decided that it was not a safe practice.
    Again, the key here is: you cannot remove the CV axle and drive. Cannibalizing a working CV with a sawsall or hacksaw is a different thing.
  13. Aug 30, 2021 at 3:07 PM
    Rachelsdaddy
    Southern NH
    Maybe some other years but my 99 doesn’t care if there is an axle in the spindle or not. It would be grouchy about the oil running out of the diff though….
  14. Aug 30, 2021 at 6:15 PM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    The axle IS the spindle. Read a book.
  15. Aug 30, 2021 at 6:42 PM
    Rachelsdaddy
    Southern NH
    You talking to me skippy? The axle slides through the spindle. Try harder.
  16. Aug 30, 2021 at 8:08 PM
    GuacIsExtra
    GuacIsExtra Well-Known Member
    2021 TRD Off-Road 6MT Cement DCSB
    :popcorn:
  17. Aug 31, 2021 at 11:11 AM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    :brianr:
  18. Aug 31, 2021 at 11:18 AM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    To be fair this is good advice.
  19. Aug 31, 2021 at 12:43 PM
    Rachelsdaddy
    Southern NH
    Ehhhhhhhh…. Good times
    Clay_916[QUOTED] likes this.
