Stranded this morning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WRREGL, Jul 15, 2023.
  1. Jul 19, 2023 at 11:53 AM
    #121
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Ummmm....you should check out the engine failure thread.
  2. Jul 19, 2023 at 12:02 PM
    #122
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I know all brands are different but it's wild to me that seemingly dealers are throwing engines at trucks without an actually failure diagnosis. Like in GM dealer land the engine replacement has to be authorized and there are hoops to jump through for major power train component replacement such as engines, transmissions, differentials, etc such as quoting whether repair or replacement is cheaper, sending off the calibration of the control module to verify it's stock and in some situations calling and opening a case with a specific engineer which is often just leaving a voicemail until they can call you back from where ever in the continent they are. But no matter even if it's something like the engine is seized before the ball can start rolling you have to pinpoint the failure and cause of failure along with photos to Gm Canada(usa) so if the engine is locked up from lack of oil you need to send a picture of the leak/ oil consumption cause along with photos of the bearings and crank being thrashed or whatever along with your written story which in that case would be along the lines of "due to metal being circulated through the engine and the complete and adequate cleaning of all oil galleries not being guaranteed feasibly whole engine assembly will require replacement, all to proving and back up that the engine is not salvage-able
  3. Jul 19, 2023 at 12:06 PM
    #123
    ColoradoTJ
    Colorado
    Under warranty Toyota sure does try to find root cause. Out of warranty...not their 11K.
    Travlr and doublethebass like this.
  4. Jul 19, 2023 at 12:20 PM
    #124
    joba27n
    Nolan
    Alberta
    Fair enough, I just figured with a routine down it wouldn't be much to stick a camera in the valve cover or drop the lower oil pan and look for evidence of the engine actually being poached and not just a siezed solid alternator or something
    Travlr and ColoradoTJ[QUOTED] like this.
  5. Jul 19, 2023 at 12:21 PM
    #125
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Oh man that sucks! Love to know the reason. I love my Tacoma, but these are starting to make me question the longevity as I am over 80k trouble free on the engine and this is when it happens. Good luck!
  6. Jul 19, 2023 at 12:26 PM
    #126
    3rdGenJen
    3rdGenJen Well-Known Member
    2021 Cement Gray TRD OffRoad Access cab
    Snugtop Rebel, Rek Gen mudflaps, FM transmitter for Sony CD player
    Gotta ask, don't recall seeing anywhere if you have any mods or have done a tune on the engine?
  7. Jul 19, 2023 at 12:31 PM
    #127
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    What thread is that?
    JmsWms and ColoradoTJ[QUOTED] like this.
  8. Jul 19, 2023 at 12:36 PM
    #128
    ColoradoTJ
    Colorado
    Oh I agree with you. I personally would get a second opinion. I once had a vehicle come into my buddies shop with a "locked up" motor and needed replaced. This was the diagnosis from a competing repair shop.
    Yeah....the starter was all wadded up and tight as a frogs butthole. Replaced starter, shimmed properly.
  9. Jul 19, 2023 at 12:40 PM
    #129
    ColoradoTJ
    Colorado
  10. Jul 19, 2023 at 12:44 PM
    #130
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    I read that CAFE standards were to blame. Small pickups have small footprints and therefore need to meet a ridiculous efficiency to be sold without a fine being imposed So instead of making a more efficient small truck, auto makers simply made the foot print bigger. The bigger the foot print, the lower the mileage the vehicle has to make.
  11. Jul 19, 2023 at 12:45 PM
    #131
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    At this point you got nothing to lose (other than the cost of a tow) to get a second opinion.
  12. Jul 19, 2023 at 12:49 PM
    #132
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Thing with GM is then they'll refuse to fix it unless you pay cash even if under warranty, ask me how I know..grrr
    shakerhood likes this.
  13. Jul 19, 2023 at 1:01 PM
    #133
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I believe that most manufacturers have regional field engineers that can get called in to look at issues (there is one for another manufacturer that is a member here, he doesn't post much, though). What issues they get called in for seem to be prioritized based on potential risk to the company, so anything related to safety comes first (even if low frequency), and major component failures of higher frequency that may lead to expensive recalls and parts replacements not far behind those. Engine failures outside of warranty might take a while to reach the top priority, but a bunch of them will lead to reputational damage, which can be costly.
    While it's probably not considered widespread, it does seem that there are similarities in the failures reported here that point to a defect. But as long as they haven't identified the defect (knowing but not doing anything about it) and aren't having to pay for repairs, there is no good reason for them to look into it deeper.
    Failure rate on the 2GR is likely extremely low considering the number of vehicles it is used in. But for an individual with a single truck, failure rate is 100% if their engine blows, which sucks. Just hoping mine is one of the good ones. Hopefully OP makes it out of this one unscathed.
    D.A.S. Taco, Mikeh80 and Gfenza89 like this.
  14. Jul 19, 2023 at 1:02 PM
    #134
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Darn, sorry this happened. Best of luck.
  15. Jul 19, 2023 at 1:10 PM
    #135
    Gfenza89
    Not to mention individual maintenance , how well the truck was taken care of, oil change intervals, type of oil.
  16. Jul 19, 2023 at 1:25 PM
    #136
    joba27n
    Nolan
    Alberta
    Unless they can point to how you specifically caused the failure and that it was from misuse/abuse/modifying then it should be repaired. Like a ball joint boot being torn on a truck with a leveling kit would be covered. A ball joint pulled out of the arm on a truck with a leveling kit that tops out in suspension travel because the ball joints are at max range of motion would be customer pay
  17. Jul 19, 2023 at 3:25 PM
    #137
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Not really surprised after hearing what a buddy has been telling me lately that works on many of these Toyotas. It's just the luck of having a defective one out of the millions of these 3.5 variants toyota manufactures. Kind of makes me nervous now to.
  18. Jul 19, 2023 at 3:29 PM
    #138
    Gfenza89
    That can and is said of any vehicle ever built. Nothing man made is perfect.
    eurowner and zoo truck[QUOTED] like this.
  19. Jul 19, 2023 at 3:32 PM
    #139
    Tacoma Mike
    Southern Maine
    The new 3.5’s suck.
    I had 4 come in with in a month just before I retired.
    Sucked in valves or loss of oil pressure.
  20. Jul 19, 2023 at 5:44 PM
    #140
    zoo truck
    None
    Beginning to think our domestic qc has now infiltrated toyota.
    D.A.S. Taco and tcjacado like this.
