Stranded this morning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WRREGL, Jul 15, 2023.
  1. Jul 19, 2023 at 5:58 PM
    #141
    tcjacado
    tcjacado Well-Known Member
    Robots and computers.
    Superdave1.0 likes this.
  2. Jul 19, 2023 at 6:30 PM
    #142
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    So, have they said whether or not this is covered under your warranty? I would think it is but you never know what a dealer might try and pull.
    I think everyone reading this is really curious to know what caused this.
    Best of luck getting this resolved!
  3. Jul 19, 2023 at 10:25 PM
    #143
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Mine had the cylinder head failure notorious to the 2004,5, and most 6 years. Bought new, never towed/plowed/hauled anything heavy. Fastidious about 3K oil changes. Head let go at 70K, within the 5/100 powertrain PLUS the "secret warranty" on the head. The one two dealers claimed ignorance of until I found it in under 5 minutes on my Blackberry, and then claimed they wouldn't do it unless I paid and then argued with corporate.
  4. Jul 19, 2023 at 10:44 PM
    #144
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Oil pressure issue can be related to broken or worn off teeth on oil pump rotors , the oil pump relief valve stuck open, the strainer tube came lose.
    Oil pump housing is the part of timing chain cover and driven directly the crankshaft . Pretty simple design.
    I can see how valves can get bent by broken chain but hard to believe the chain just went kaput after 70K
  5. Jul 19, 2023 at 10:51 PM
    #145
    tcjacado
    What is a secret warranty?
  6. Jul 19, 2023 at 11:04 PM
    #146
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    I believe this happened Chris, but there has to be more to the story. Interesting how different dealerships handle business. My local Toyota dealerships are tools.
    Personally, I have never had a bad experience with GM. Then again, I'm not in the dealership needing repairs either. In the past 7 years/100k miles I have had two issues. Wheel speed sensor under 2000 miles on the truck that was intermittent. The dealership service manager gave me his personal cell phone number for when the speed sensor was tossing a code. I called him when the next time it happened and he met me out in the parking lot with a code reader, captured the issue and scheduled me for a speed sensor swap. I call that service above and beyond.
    Second time the truck was well out of warranty and the DEF tank heater went out. They covered it without an issue and had me on my way in one hour. The dealership even gave me a free oil change voucher for my inconvenience. That was just this vehicle in a long history of GM ownership with similar results.
  7. Jul 20, 2023 at 12:34 AM
    #147
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    In gm land we call it a "special coverage program" it's basically a very extended warranty on a specific component but they don't notify you about it. You just show up at the dealer with the described problem like a regular joe and suprise! Your repair is fully covered for free
    example is 2007-2013 style tahoes/suburban vehicles and their front wiper motors... 20 years or 240'000kms coverage if I remember correctly, from the original sale date of the first owner... in case thats anyone's second vehicle and their wipers stop working
  8. Jul 20, 2023 at 2:24 AM
    #148
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    Did you get a lot vehicles in per month with the 3.5?
  9. Jul 20, 2023 at 2:52 AM
    #149
    Tacoma Mike
    Southern Maine
  10. Jul 20, 2023 at 3:07 AM
    #150
    Tacoma Mike
    Southern Maine
    For some strange reason it was sporadic.
    One of my nitches was repairing the stupid hi pressure injectors. I would get one or two a week.
    The suspect hi pressure injector would look like you baked the tip in oil at 500°.
    It was a good thing I could run the two systems separate. The whole engine is way to technical.
    And things are only going to get worse.
    We had two 3.5’s in a two week period break valves.
    One had 350 miles, the other had around 700.
    All I know is I don’t have to put up With it anymore…
  11. Jul 20, 2023 at 5:59 AM
    #151
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    I thought these engines had self cleaning fuel injectors
    ktbell444 and D.A.S. Taco like this.
  12. Jul 20, 2023 at 6:25 AM
    #152
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Don't blame the robots, and computers, its the people that program them what to do.
  13. Jul 20, 2023 at 6:58 AM
    #153
    eurowner
    eurowner Duke Sky
    Scoty
  14. Jul 20, 2023 at 7:03 AM
    #154
    Tacoma Mike
    Southern Maine
    Just like they have self adjusting brakes lol. And they do have a self cleaning program however, doesn’t always work.
    RustyGreen and Gfenza89[QUOTED] like this.
  15. Jul 20, 2023 at 7:04 AM
    #155
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Question: Why don’t the British make televisions?
    Answer: Because they cannot figure out how to make them leak oil.
  16. Jul 20, 2023 at 7:06 AM
    #156
    eurowner
    eurowner Duke Sky
    Scoty
    Why do the English drink warm beer?
    Lucas refrigerators.
    Vmax540, Travlr and shakerhood like this.
  17. Jul 20, 2023 at 7:10 AM
    #157
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    They have cleaning cycles that use the port injectors to clean the valves. The "self-cleaning" referred to is how the engine cleans the valves itself during this process.
  18. Jul 20, 2023 at 7:15 AM
    #158
    BLtheP
    Plano, TX
    It really is a pretty underwhelming engine overall. It has 4-5 well known flaws that haven't really been addressed. It makes mediocre power and all of it is at the very top. I like my truck but these trucks simply would have been better with the dual VVTI 4.0 motor instead. The 3.5L definitely seems much more complicated than it needs to be based on the digging I've done in the FSM.
    LilTexan22 and Superdave1.0 like this.
  19. Jul 20, 2023 at 7:16 AM
    #159
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Exactly!
    Folks here forget we're on an forum where a small complaint about steering wheel button layout can yield multiple pages of chatter. The 3.5 is used across quite a few models in their lineup with success.
    ToyoTaco25, BumfukKansas and joba27n like this.
  20. Jul 20, 2023 at 7:17 AM
    #160
    Gfenza89
    Not according to chief engineer mike sweers who explained how the direct injectors have slits on the sides of them and at certain idle conditions it will spray the sides of the injectors to blow the carbon off.
