Stranded with a key that won't turn in the ignition.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larzzzz, Aug 4, 2018.
  1. Aug 4, 2018 at 2:31 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    This was a lifesaver when I lost my keys at 6 flags... on a rollercoaster.
  2. Aug 4, 2018 at 2:38 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Been doing this with my wife's car also,saves me lots of hours running out too her with an extra key.lol
  3. Aug 4, 2018 at 2:39 PM
    lynlan1819
    Tacoma
    Lifted
    Saves you lots of dollars also by not having too call someone out too make you a key.
    scottalot likes this.
  4. Aug 4, 2018 at 2:48 PM
    Muddinfun
    Muddinfun Well-Known Member
  5. Aug 4, 2018 at 2:49 PM
    Larzzzz
    Larzzzz [OP] Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    An f'ing Hammer... Tap tap tap with a hammer on the new key in the lock and it turned. PSYCHE!
    I can make this work. I can leave this plain key in the ignition and still start the truck with the remote starter.
    Sidney Vicious and Muddinfun like this.
  6. Aug 4, 2018 at 2:53 PM
    Muddinfun
    COOL! Now don't turn the lock all the way to the lock position til you get the lock fixed. That link I posted describes the trick to getting the lock cylinder out.
    The wafers were gummed up. A good locksmith can take it all apart and clean it all out.
  7. Aug 9, 2018 at 5:04 AM
    Larzzzz
    Larry
    MA
    Thought I'd update...
    Turning the truck off does NOT reset the immobilizer. That happens when the key is removed. Got tired of hammering the key, so i removed the cylinder.
    Called around for a new ignition cylinder and was quoted $312. from the local dealer and $272. from the dealer near home. That does not include programming the new keys.
    Called locksmiths and got a price of $150. to rebuild and 2 new keys. Taking the transponder out of my keys and putting them in New shells. I said ooook. Found a locksmith down here that'll rebuild it for $35. no keys. I'll use the one i had cut at the dealer to make keys from blanks I'll get on Amazon and I'll get that key programmer from eBay.
    Looks like I'll have it all fixed for under a C note.
    bigmw and Muddinfun like this.
  8. Aug 9, 2018 at 5:11 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    This will probably be a bigger problem with smart keys and push button ignition.
  9. Aug 9, 2018 at 5:14 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Nice. Let us know how it turns out.
  10. Aug 9, 2018 at 5:21 AM
    Larzzzz
    Larry
    MA
    The cylinder should be ready today...
  11. Aug 9, 2018 at 7:14 AM
    Weissenheimer
    Weissenheimer Well-Known Member
    Bryan
    Southern Maine
    05 TRD O/R (desert sand mica)
    FN FX wheels, Dobinsons suspension, air bags, other bells and whistles
    I used to be a locksmith way back when. Very common problem with these Toyota’s. It’s kind of a design flaw but mostly a result of the “split” wafer system in your lock cylinder. I believe there are 8 normal wafers and two pairs of split wafers at the tip. Split wafers bend easily and over the years become the weak link in the system. The other half of the problem is Toyota’s “tip stop” keys which wear out and change where your key stops when you push it in.
    You got the right idea bringing the cylinder to get repaired by a local locksmith. Where I used to work it was $35 yo repair if the cylinder wasn’t bunged up. And then we would cut/clone you a new key to factory spec to fix the tip stop issue.
    From my experience when customers try to “be a hero” and program their own keys they only throw money away. it’s no guarantee that you can get it to program. Curious to see how this goes
  12. Aug 9, 2018 at 7:34 AM
    Larzzzz
    Larry
    MA
    Not trying to be a hero. Just trying to save a few bucks. I've had keys made/programmed before. It's not cheap.
    And as I was stuck in this parking lot calling locksmiths, of the 4 I called, one called back, and in not so many words said, I'm not coming out there; a 20 minute drive...
    You tube to the rescue...
  13. Aug 9, 2018 at 7:44 AM
    Weissenheimer
    Bryan
    Southern Maine
    yeah I understand. Local guys are usually too busy or understaffed to travel that far for little payout haha. Also I have to mention, Beware of “fly by night” locksmiths that take over the top results in google searches. They often go with generic names or even ones similar to legit local locksmiths. And long story short they will charge insane amounts to fix your problem, or leave you hanging in the end
  14. Aug 9, 2018 at 7:51 AM
    Larzzzz
    Larry
    MA
    Doing my best to not let that happen...
  15. Aug 9, 2018 at 10:19 AM
    #35
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Just out of curiosity, how much stuff do you have on your key ring with the truck keys?
  16. Aug 9, 2018 at 10:45 AM
    #36
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
  17. Aug 9, 2018 at 10:48 AM
    #37
    Larzzzz
    Larry
    MA
    4 keys, 2 of which are for padlocks. A 2 way remote and an attachment that let's me add another key or small ring to. It's hardly ever used, but very convenient when needed.
  18. Aug 9, 2018 at 10:49 AM
    #38
    Larzzzz
    Larry
    MA
    I have a ring of keys something like that. Lol
  19. Aug 11, 2018 at 7:30 AM
    #39
    Larzzzz
    Larry
    MA
    The rebuilt cylinder works great and the original key still works. It's kinda sticky though so I'll use the non chipped key for now.
    bigmw and PzTank like this.
  20. Aug 11, 2018 at 8:10 AM
    #40
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Just saw this, same thing happened to my 07 after about 250k miles. Took the cylinder out, used a screw driver for a day or so and had a locksmith rebuild the cylinder to match my existing keys. $35-40 and it worked perfectly. No new keys. Congrats OP.
    bigmw likes this.
