strange 01 tacoma sounds
Discussion in '1st Gen. Tacomas (1995-2004)' started by cwitters86, Jul 17, 2010.
  1. Jul 17, 2010 at 10:34 AM
    cwitters86
    cwitters86 [OP] Member
    seattle
    01 prerunner sr5
    i have a 01 tacoma 2 wheel drive v6 wih 155k miles and it has been making some strange sounds and was wondering if anyone what they were and what to fix.
    sound #1
    1 out of 8 times when i start up my truck i hear a screeching/squeeling sound coming from the engine bay. a buddy of mine says that the alternator belt needs to be replaced from usual wear in tear over the years, would replacing the belt eliminate the sound?
    sound #2
    when driving going around residential roads when i hit pot holes or bumps in the road i can hear something rattling underneath the truck when my windows are down. it sounds like exhaust might be loose but ive gotten underneath the truck and shook everything i could find to imitate the problem but can't seem to find it. is there anything that generally breaks loose from this model and year truck that i can narrow down the prob?
    let me know if anyone can help with these lame issues for an OCD tacoma driver, they are making me crazy! thanks
  2. Jul 17, 2010 at 10:41 AM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    1) Replace all 3 belts.
    2) You will have to get under the truck and start hanging/banging on things and see if something is loose.
  3. Jul 17, 2010 at 11:32 AM
    cwitters86
    seattle
    01 prerunner sr5
    easy to replace and how much are the belts going to run roughly?
  4. Jul 17, 2010 at 11:36 AM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    my skid plate was rattling. you should check the bolts on it too..
  5. Jul 17, 2010 at 11:43 AM
    quattrokiwi
    Bruce
    Nor Cal
    About $60 if you get the higher quality ones. easy to replace, I would say yes, just a little time consuming, mainly the ac belt as you have to take the skid plate off to get at the tensioner.
