Strange 1997 Tacoma 3rz misfire
Discussion in '1st Gen. Tacomas (1995-2004)' started by marshallantony, Jan 15, 2021.
  1. Jan 15, 2021 at 8:36 PM
    marshallantony
    marshallantony [OP] Member
    Marshall
    2012 Tacoma TRD Sport 4x4 MT
    Methods, Patagonia MT-2, Bilstein 6112 and 5160s
    Hello all, today I got a strange misfire. I started the truck and when idling it was totally fine, then under acceleration it misfire and pops and bangs. I went to the store and bought injector fuel cleaner and the problem went away. Later today it started again but super randomly. I’m thinking fuel filter or injectors.
    Any suggestions? Thanks
  2. Jan 15, 2021 at 9:06 PM
    sharkrocket
    sharkrocket Member
    Mark
    Rancho Cordova, CA
    96 Reg Tacoma
    I used to have a cylinder #1 misfire. It would show up at acceleration from a stop and 40+ MPH. I replaced the fuel injector and it went away. Later on I began to get multiple misfires, tore down the motor and found tons of cracks on the cylinder head around the spark plug. Ended up having to replace the head.
  3. Jan 15, 2021 at 9:29 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    You could have gotten some fuel with a bunch of water in it. Have you had any heavy rains lately? Gotten fuel from some different station then you normally use?
  4. Jan 15, 2021 at 9:34 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Pull the fuel filter and see if it's clogged, if it is that's likely your problem, if it isn't your next step would be to check if your MAF sensor is dirty, if it's clean you need to check fuel pressure.
  5. Jan 15, 2021 at 9:59 PM
    marshallantony
    Marshall
    I’ll pull it when I have some time, MAF is clean so I’ll try and check fuel pressure as well. Thx
  6. Jan 16, 2021 at 12:30 AM
    marshallantony
    Marshall
    I have actually gotten some heavy rain over here, same gas station though. I’ll fill up soon and let you know how it goes
  7. Jan 16, 2021 at 4:25 AM
    gearcruncher
    Canadain bumper technician
    have you checked for codes ?
  8. Jan 16, 2021 at 11:53 AM
    marshallantony
    Marshall
    Yes I got a random misfire and a 3rd cylinder misfire, I forgot the names of the codes.
  9. Nov 29, 2021 at 8:55 PM
    marshallantony
    Marshall
    Hello everyone. I still seem to have the same problem.
    It comes back every other month or so and I have no clue what it is lol.
    The issue will start when I turn on the truck and it will immediately start idling rough, that’s the oh shit stage when I know it’s gonna drive like shit. After that when I’m driving super slow and super light acceleration it doesn’t accelerate super rough. Once I start to accelerate the misfire feeling starts to happen. The only way I can get it to go away I’m the moment is so put it in neutral and rev it up a couple times. Almost feels like it’s clearing it’s throat.
    Things I have tried.
    Spark plugs
    Leads
    Ignition packs
    Coolant temp sensor and sender
    Cleaned throttle body
    Cleaned maf
    HAVENT TRIED
    fuel filter
    TPS
    Injectors
    Idk what else
    and lastly it’s not bad gas
  10. Nov 30, 2021 at 6:47 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    A leaking head gasket will kill a couple of cylinders until it they heat up and blow out.....
    the leak starts slow and intermittent, occasional and gets worse.....
    next stage you have pull a couple plugs and dry em off to get to start.....
    hard to restart after sitting 30min or longer.......
    Using sealants may ruin radiator and/or heat core......
