Strange A/C issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Old Tex, Jun 2, 2015.
  1. Jun 2, 2015 at 2:22 PM
    Old Tex
    Old Tex [OP] Well-Known Member
    South central Texas
    12 four door, 4X4
    Howdy all you folks,
    I am having a strange problem with my A/C. The drivers side is fine but the passenger side blows cool, not cold air. I have never had this happen with a vehicle before. Any suggestions are appreciated. Have a goodun!!!!!!!!!!!!!
  2. Jun 2, 2015 at 2:49 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Perhaps One of the doors not closing all the way allowing warm air in on one side.
  3. Jun 2, 2015 at 3:01 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Air is blown by the same blower so perhaps there's some kind of obstruction in the passenger side vent tube.
  4. Jun 2, 2015 at 4:35 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Have you cleaned the cabin air filter recently?
    File IFR likes this.
  5. Jun 2, 2015 at 4:40 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    ^^ This
  6. Jun 3, 2015 at 2:48 AM
    Old Tex
    South central Texas
    12 four door, 4X4
    Howdy,
    yep, I just changed the cabin air filter. The air still comes out of the passenger vents. It isnt cool like the driver vents. I know it sounds goofy but it is happening. Many thanks for the replies. Have a goodun!!!!!!!!!
  7. Jun 3, 2015 at 12:48 PM
    savedone
    Gerald
    Texas
    Many times what we think we feel in temperature is not reality. I suggest that you use a digital thermometer to check each vent and see what the actual temperature difference is instead of relying on feel. .
    Also you might get a digital hydrometer and check each vent. A difference in RH can make things feel a lot different than they actually are and the RH can differ significantly from vent to vent.
    I recently checked my truck and it was blowing around 46 degrees with an outside temp of 88. However the RH (relative humidity) was around 35 or 36. That is a little low which means the air will not feel as cold as it is. A better RH would be between 45 and 50. What this tells me is that these trucks have too large of a system and lowering the RH a little too much for comfort. One way to help this out is not run the system on internal circulation. It is fine for about the first 10 minutes but after that it needs to be turned to outside inlet.
  8. Jun 3, 2015 at 1:37 PM
    Jrahn0822
    Jrahn0822 Well-Known Member
    Jake
    Iowa
    07 DCLB
    Have it checked to see if you have a leak or are low on Freon. I had the same issue and it was almost a pound low on Freon. Found the culprit to be an o ring on a service port. Got it fixed and now it's blowing nice and cool in all vents.
  9. Jun 3, 2015 at 1:41 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    ^this
    I've seen, mostly on dual climate control cars, it blow cold on one side and not so on the other due to it being low on refrigerant. You should get it checked out.
  10. Jun 3, 2015 at 2:55 PM
    Old Tex
    South central Texas
    12 four door, 4X4
    Howdy,
    many thanks to you guys who responded!!! I value your input and will have the freon checked out. Thanks again and have a goodun!!!!!!!!!!!!!!!!!!!!!
  11. Aug 3, 2015 at 5:25 PM
    Tacoma675
    Tacoma675 Well-Known Member
    Drew
    Kingwood,Tx
    2014 4x4
    Husky floor mats
    I have the same problem. Did you find out what the problem was?
