Strange brake problem
Discussion in 'Technical Chat' started by yodataco, Aug 2, 2010.
  1. Aug 2, 2010 at 4:23 PM
    yodataco
    yodataco [OP] New Member
    I have a 2007 Tacoma standard cab 4 cylinder. I have a brake line leak somewhere that is causing my driver side floorboard and mat to get saturated in brake fluid. Any idea where the hell this would be coming from?
  2. Aug 2, 2010 at 4:28 PM
    YeahYeah
    YeahYeah Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
    look underneath the car and follow the brake line. more than likely you hit something that could have ripped the line. but weird that its leaking inside!
  3. Aug 2, 2010 at 8:04 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Is it a manual trans? The clutch master cylinder uses brake fluid. It's inside the cab on the clutch pedal linkage.
    The brake master cylinder is in front of the firewall. It would have to leak through the vaccum booster to get into the cab from there.
