Strange "Chirping" sound when turning.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Guerrilla, Sep 22, 2014.
  1. Sep 22, 2014 at 2:43 PM
    Guerrilla
    Guerrilla [OP] L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    I've been having a strange chirping like sound when turning (coming from the front end area), it's intermittent.. At first I thought it may be the tires squealing because it's similar in sound, but I'm not totally convinced that it is.. I had a Toyota Tech ride with me, and he said he didn't know what it was and had never heard that sound, and was perplexed.
    I would try and get a video, but even if I caught it at the right time, I don't believe it would capture the sound well enough..
    Any ideas or anybody else heard anything like that on their truck?
  2. Sep 23, 2014 at 8:12 AM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
  3. Sep 23, 2014 at 8:16 AM
    Adamar85
    Adamar85 Well-Known Member
    Adam
    Baker City, OR
    22 Ford F350 Lariat
    I have the same, but I think mine is due to being a little out of alignment. It started on mine after I installed my Total Chaos UCA's and cranked the coilovers a half inch. Will let you know if it goes away
  4. Sep 23, 2014 at 11:23 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    My tires chirp when I turn, but my alignment is way off. Yours might be, too.
  5. Sep 23, 2014 at 4:18 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Power steering fluid filled? I've head the P steering pump chip on some cars. Those may have been the belt slipping, but I would say not with the cogged belt. Get a mechanics stethoscope and have a buddy sit behind the wheel and turn the wheel ....
  6. Sep 23, 2014 at 5:41 PM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    I've heard noisey power stearing pumps and belts. I wont eliminate those.. But for some reason I don't think it's either. Altho it's possible.
    The alignment is pretty much dead on. It's been checked etc. PS fluid is good.
    I wish there was a way to get the sound on video. It's weird and perplexing. It almost sounds like a turkey call, if you just chirp it.
  7. Sep 23, 2014 at 5:59 PM
    Canufixit
    New England
    Does it only do it at idle/low speed or can you hear it at a higher RPM ???
    I had an old 74 Monte Carlo that did this and it was a Vacuum line that got all oiled up and expanded on the Vacuum fitting .... it was sucking in air at the fitting and kinda sounded like your noise??
  8. Sep 23, 2014 at 6:03 PM
    Rockoma5
    Rockoma5 Well-Known Member
    St Louis
    2019 TRD Sport Lifted
    What about a suspension component that needs grease?
  9. Sep 23, 2014 at 6:16 PM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    No it doesn't sound anything like air being sucked into a fiiting or line.
    It's at lower speeds and up to around 40ish, but that's basically because the amount or degree of turning at higher speeds is reduced. It's more when turning in the mountain roads or onto to a road, not like a sweeping turn on the highway. And it will only do it once in a single turn. Not continually.
    Yeah It does have some sort of sound like it could be from something in the suspension. But I cant think of what two things would be moving in a way against each other to make that noise.
  10. Sep 23, 2014 at 6:40 PM
    Canufixit
    New England
    quote "Yeah It does have some sort of sound like it could be from something in the suspension. But I cant think of what two things would be moving in a way against each other to make that noise. "
    Steering Rack??
  11. Sep 23, 2014 at 6:44 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    I notice some tire chirp coming from my spare tire when it has lost a little air over time and is no longer snug. Easy to check by reacing through the wheel well, grabbing the spare and giving a shake....
    Probably not your issue, but easy to check...
    David
  12. Sep 23, 2014 at 7:10 PM
    Canufixit
    New England
    Actually, That's a good thought.
    Also, although more mechanical - I'm thinking of the centrifugal force an a low speed turn. I'd check anything that might shift. Exhaust, heat shields, anything that may move ....
    Does it do it when the truck is stationary ???
  13. Sep 27, 2014 at 5:01 PM
    Adamar85
    Adam
    Baker City, OR
    22 Ford F350 Lariat
    Got my alignment done and mine went away.
  14. Sep 28, 2014 at 3:04 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I got it too. (Think we can initiate a recall?lol) I'm changing my hubs (drivers side is bad). I'll see if it goes away, and let you know.
  15. Sep 28, 2014 at 3:36 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    You might want to slow down! Lol
  16. Sep 30, 2014 at 2:38 PM
    robssol
    Rob
    S. Wisconsin
    I have not heard the chirp since I installed the new hubs.:D
  17. Sep 30, 2014 at 9:38 PM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    Yeah I'm sure it's not from there. But thanks anyway.
    No only when moving and turning.
    Thanks for the update.
    Thanks for update. I wouldn't think my hubs are bad, it's only a 13, but anythings possible.
    No it's not at full lock. Pretty much about a quarter turn to a third.
    Thanks for the input.
    Trying to track this noise down is a pain. Especially since it does it only while moving and turning.
    My main concern really is, if it's the begining of something going wrong or bad, I'd like to catch it before it fails. Hopefully it's nothing.
  18. Oct 4, 2014 at 8:17 PM
    Foxer
    Foxer Well-Known Member
    U.S.A.
    Access Cab PreRunner
    Mine does the same thing.....
  19. Dec 12, 2014 at 12:07 AM
    Twinkie0311
    Twinkie0311 Mall crawling like a boss
    Hillsboro, Oregon
    13 DCLB TRD Sport MGM
    OME Lift w/ Dakars, TRD catback exhaust, 275/70/17 with SCS Stealth 6. and much more.
    OP mine does the same thing. I've been trying to figure out what it is as well. I tried to capture it once, but it was too hard since it only happens when I'm driving and making a slight turns sometimes. The best way I can describe the sound is it sounds like you are using the washer fluid. that sound.
    weird. I'm gonna have a dealership look at it soon if it comes up again to be safe
  20. Mar 28, 2017 at 1:44 PM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Thread revival any update to this? I noticed a chirping @ 75-80 mph coming back from my last offroad trip.
