Strange clunk noise from front suspension
Discussion in 'Technical Chat' started by 06Bluez, Apr 13, 2009.
  1. Apr 13, 2009 at 10:55 AM
    06Bluez
    06Bluez [OP] Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    Ok so im getting some strange clunking noises coming from the front end of the truck. It happens when steering, hitting bumps, turning into an elevated driveway or roadway, and when braking. Sounds like its coming from the front left of the truck.
    I can't figure out what it is.. Anyone have any ideas?
  2. Apr 13, 2009 at 10:57 AM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    are you cranked to the full height?
  3. Apr 13, 2009 at 11:03 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    I got it too but only when conditions are wet. started right when i put the uca's on
  4. Apr 13, 2009 at 11:04 AM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    New Bern NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
  5. Apr 13, 2009 at 12:49 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    I actually have the coils cranked quite low.
  6. Apr 13, 2009 at 1:39 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    I dont have CV's cuz im a pre runner so it cant be that. And the noise definatley isnt coming from the UCA's Chris4x4 installed and greased them himself. The noise is coming from lower then the UCA's I can feel the clunking on my feet as well as hear it.
  7. Apr 13, 2009 at 1:42 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    have you checked every bolt you took out to do your lift is re-torqued good
  8. Apr 13, 2009 at 1:42 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    I have 4x4 but your describing my problem exactly, I'm thinking lower ball joints or wheel bearings. How many miles are on your truck?
    hahaha What??? ^^^
  9. Apr 13, 2009 at 1:45 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    I too have that clunk and have now clue what it could be i had my c/o's at 2.5"+ and cranked them down but i only feel theclunk after bumps
  10. Apr 13, 2009 at 1:51 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    Weird ^^^ my F'n clunk only happens when everything is wet
  11. Apr 13, 2009 at 1:52 PM
    TacoNut
    Adam
    Denver, Co
    I can spell.... I SWEAR!!!!
  12. Apr 13, 2009 at 1:58 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    35k miles on truck. Everything was fine until an alignment that I got then it started clunking. I think the caster is still off. Could that be it?
  13. Apr 13, 2009 at 2:01 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    well its funny you say something about the alignment because that noise originated with the correction of alignment/new uca's paired with the lift. I didnt have the noise when I had the stock uca's and lift/bad alignment????
  14. Apr 13, 2009 at 2:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Could be your tie rod ends. Hope they didnt fuck them up when aligning it. Also check your battery mount.
  15. Apr 13, 2009 at 2:34 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    Believe me you can feel the clunk with your feet just have no clue what it is.
  16. Apr 13, 2009 at 2:36 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Battery mount?? ok.. The caster off according to the alignment specs. Could that be a reason Chris? Ill post up the alignment specs when I have a free moment here at work.
  17. Apr 13, 2009 at 2:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    One thing at a time...Go out, pop your hood, and make sure the battery is secure.
  18. Apr 13, 2009 at 2:59 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Will do except im at work right now. Ill check it out when I get home and ill also post up the alignment specs.. It looks like they got the caster way off.
  19. Apr 13, 2009 at 5:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Give me a call when you get home.
  20. Apr 13, 2009 at 6:15 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Will do sir. Thanks Chris
