Strange dash lighting problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mkZero, Mar 30, 2010.
  1. Mar 30, 2010 at 9:04 PM
    mkZero
    mkZero [OP] Well-Known Member
    Brian
    OC CA
    2010 FJ 4X4
    Hey all. I'm having a weird issue with some of the dash lighting in the 05 Taco I just bought. The lighting for the automatic transmission gear selector in the center counsel (P R N D 4 etc) doesn't light up nor do the dials for the heater/AC when driving at night (with the lights on), but both of those things light up when you disarm the alarm system. So the bulbs aren't burnt out, and they obviously *can* receive power. All other instrument lights work fine. Help! :confused:
    PS. I searched and found this thread, which seems to indicate that those things should be illuminated. --> http://www.tacomaworld.com/forum/2nd-gen-tacomas/21208-lighted-shift-selector-2.html
  2. Mar 31, 2010 at 4:50 PM
    mkZero
    Brian
    OC CA
    2010 FJ 4X4
    Anyone? :(
  3. Mar 31, 2010 at 5:07 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Since no one has spoken up yet, I'll at least say that someone likely didn't install the alarm correctly. Since they don't come with alarms from the factory, it's an aftermarket install. You might try getting a copy of the installation instructions for your alarm system then trace the wires to see where they were connected (correctly or incorrectly).
  4. Mar 31, 2010 at 5:09 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    ^^Agreed
  5. Mar 31, 2010 at 9:03 PM
    mkZero
    Brian
    OC CA
    2010 FJ 4X4
    Hmmm, I was wondering if it had something to do with the alarm... Thanks for the suggestion. So they didn't come with alarms? The remote for the alarm has a Toyota symbol on it, so I assumed it came with it.
  6. Apr 1, 2010 at 6:56 AM
    05Moose
    Jim
    All the toyota alarms are installed aftermarket. The dealerships usually have one company they use to install the alarms. Around here in Sacramento, it's a business called Dealerworks. They install things like sunroofs, heated seats, alarms, etc. Some of these things aren't available from the factory, but they're added on by the dealership.
