Strange driving experience on wet roads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by burnside, Nov 1, 2015.
  1. Nov 1, 2015 at 10:45 PM
    burnside
    burnside [OP] Member
    Yesterday we had some freak flooding in the northwest. I decided to switch from 2WD to 4WD (H4) on my 15' DC SR5 due to the slippery roads and mud in the area. Everything was fine until I had to make a U-turn. Coming out of the turn it felt like the wheels locked up or jittered - I don't think they were spinning. It caused me to brake to a stop before I tried again to complete the turn. I know I don't have rear lock either since this is a non sport/trd model.
    Any idea what may have happened? Closer to home I switched back to 2WD. Again, everything fine until right before I pulled into the driveway I made a tight turn and the same jittering happened again. Makes me worried when the real icy weather comes in. I have an AWD Acura and have driven it in all sorts of nasty weather but have never had an experience like this. I'm hoping it's just my inexperience with a 4WD Taco that's the reason.
  2. Nov 1, 2015 at 10:50 PM
    burnside
    OK, I got some learning to do! Thanks for the reply. So what should I have done in this case? Taken the turn slower? edit: or not as sharp?
  3. Nov 1, 2015 at 10:51 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Make u turns in 4wd not good. Straight line, good.
    Simon's Mom likes this.
  4. Nov 1, 2015 at 10:52 PM
    burnside
    LOL. OK, this is helpful. Man I'm green when it comes to this.
  5. Nov 1, 2015 at 10:53 PM
    burnside
    Got it. Thanks a bunch!
  6. Nov 2, 2015 at 12:53 AM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I understand it jittering during the u-turn in 4wd, but you also said it did the same thing in 2wd when you got home?
  7. Nov 2, 2015 at 5:38 AM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    That concerns me also. I've never had that happen. Could you tell us more, Burnside?
  8. Nov 2, 2015 at 7:45 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    sounds like it was still in 4wd. maybe he switched to 2hi right before his driveway, and it didn't get a chance to disengage before turning.
    numbah57 likes this.
  9. Nov 2, 2015 at 8:37 AM
    burnside
    That's what I'm thinking. I switched to 2hi about a quarter mile before the driveway going uphill. The next morning when leaving I made a uturn and it performed just fine.
  10. Nov 2, 2015 at 8:38 AM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    If the driveline is bound up in 4 wd it may not go into 2 wd even though the selector has been moved to 2 h. Stopping and backing up in a straight line can help "unbind" the driveline. Then the 4 wd indicator light should turn off indicating you are actually in 2 wd.
  11. Nov 2, 2015 at 8:44 AM
    burnside
    Good to know. The 4WD indicator did go off, but it was still probably stuck in 4WD. I'll try your suggestion next time.
  12. Nov 2, 2015 at 9:31 AM
    Backt
    Oregon
    Would there be any damage done with it binding up like this 2 times. It's certainly not advised but is it something he just needs to forget about or should he have it checked being its such a new vehicle?
  13. Nov 2, 2015 at 2:20 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I thought we had a sticky somewhere on how to use 4WD, but I can't seem to find it.
    If the truck still drives normally in 2wd and 4wd, it is fine. The weakest points will be the CVs/U-joints, they would likely go first. He just caused a bunch of extra stress on the driveline components. Just don't do it again. 4wd should not be used on wet pavement. The only time it should be used on pavement is in the snow. If you cannot see the pavement due to excessive mud, then I would no longer classify it as pavement.
  14. Nov 2, 2015 at 2:31 PM
    burnside
    Should I have a mechanic look at anything the next time I bring it it? I watched some videos last night on partial, full time, and all wheel drive. I get it now and will never do it again. Learned a good lesson.
  15. Nov 2, 2015 at 2:41 PM
    burnside
    Thanks for all your help. Great forum of users here.
  16. Nov 2, 2015 at 4:28 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    In general, Wet and dry pavement- never use 4wd. If you need 4wd on wet/dry pavement for any reason, no sharp turning. Keep it straight as possible.
    Any time you drive anything but a straight line in 4wd, ALL 4 tires will want to travel at 4 different speeds. The sharper the turn, the bigger the difference in speed of each tire. With a taco in 4wd, the wheels CAN'T spin at different speeds. To compensate, each tire "slips" on whatever surface they are sitting on. This may have been the jitter you felt.
    If it's a grippy surface (pavement), pressure will build up in the driveline until one of two things happen: (1) the tires eventually slip on the surface and the tension is released or (2) something will break on the truck to release tension. The grippier the surface (and sharper the turn), the more the tires/driveline bind (pressure builds that that will eventually release in one of the above two ways). When you are on snow/mud/slush/ice the tires are able to "slip" independently as necessary, avoiding any binding.
  17. Nov 2, 2015 at 4:40 PM
    NMTrailRider
    New Mexico
    You might like to check out this thread, OP.
    https://www.tacomaworld.com/threads/4x4-questions.397438/#post-11006549
    I provided some additional links to 4wd info in post #13.
  18. Nov 3, 2015 at 8:13 AM
    tgear.shead
    tgear.shead Well-Known Member
    4wd is massively overkill for WATER.
  19. Nov 3, 2015 at 9:25 AM
    burnside
    Is that a tutorial for salesmen? I watched the entire thing and wish something like it was available at purchase. Very good info and I feel way more confident now. Really, I tend to not even drive if it snows unless absolutely needed. Still, let's say the roads are snowed and icy and I see a pretty sharp turn up ahead. What's the best course of action?
  20. Nov 3, 2015 at 12:08 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    The snow and ice will allow slippage - slow down to a reasonable speed for conditions and continue on.
