Strange drum brake noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Motofox, Jul 4, 2018.
  1. Aug 19, 2022 at 3:16 PM
    #41
    0ne0ff
    0ne0ff Dirt Road Scholar
    New Brunswick
    2010 Tacoma AC
    OME lift in all 4 corners mesh grill Dixie horn tinted custom shotgun box
    Did it work for you? I’m having the same issue, not air in the lines, not the shoes, not the drums, not the hardware, not a dry backing plate, and not the adjustment. Only thing I have left to replace are the backing plates and bearings and I’m getting tired of throwing money at this f*****g problem without even an iota of improvement.
  2. Aug 23, 2022 at 11:17 AM
    #42
    rodypin
    rodypin New Member
    Rody
    2022 Tacoma
    @0ne0ff no creaking sound is still their. Dealership can’t figure it out. Don’t want to void the warranty by taking to someone else.
  3. Aug 23, 2022 at 12:16 PM
    #43
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Are there other dealers in town? You don't have to take it to the dealer you purchased it from. Any Toyota Dealer will honor the Warranty. It will not void the warranty.
  4. Aug 25, 2022 at 7:48 PM
    #44
    0ne0ff
    New Brunswick
    2010 Tacoma AC
    Dang. On mine the sound is also audible around 20km/h(12mi) and below with the brakes on.
  5. Aug 25, 2022 at 11:38 PM
    #45
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    That original video did sound like related to the ABS pump. Never really knew what the DIY first job and then the shop did but hard to believe no one bled the system at some point.
    Turn you key to ON not starting it and listen to the ABS pump - then when it stops press the brake pedal and listen/feel any oscillations.
    Any air compresses in the brake line results like the new washing machines and having to add a water line damper but you still hear the water valve knocking as it fires on/off - just like the ABS pump would.
