Strange Electrical Problem
Discussion in 'Toyota Trucks & SUVs' started by Buzzman1, Dec 27, 2013.
  1. Dec 27, 2013 at 4:44 AM
    Buzzman1
    Buzzman1 [OP] New Member
    Buzzman1
    Tacoma 2.4l 2WD
    My 02 Tacoma has a strange electrical problem. The left headlight won't work in low beam but the bulb is good. The strange part is the passenger side Turn Signal (which also lights up when you hit the brake) works but doesn't when you hit the brakes as its supposed to. The bulb is also good. Any ideas?
  2. Dec 27, 2013 at 4:48 AM
    Large
    Large Red
    Sounds like a bad ground somewhere, or the ground is getting 12V when it's not supposed to. You would need a wiring diagram to know for sure, I'm no expert in first gens :-\
