Strange feeling when I come to a stop.
Discussion in 'Technical Chat' started by Gooiegoogoo, Sep 26, 2013.
  1. Sep 26, 2013 at 4:51 PM
    Gooiegoogoo
    Gooiegoogoo [OP] Well-Known Member
    Gustavo
    Phoenix
    03 TRD SR5
    2" lift
    2003 V6 automatic 4x4 86,000 miles
    This issue has become a bit more noticeable within the last month.
    My usual braking pattern: I don't ride the brakes to a stop rather I anticipate the stop and begin slowing down ahead of time by pressing the brake and letting go, riding it out for a couple hundred feet, then pressing the brake again, a bit harder, and then letting go to ride and then come to the complete stop.
    Description: When I come to the complete stop some times I feel a light jolt as soon as I let go of the brake. It is slight, the truck doesn't lurch forward but it is very noticeable. It feels as if there is some sort of residual thrust left. I gave the shifter some attention and when that happens I notice it too sort of thrusts.
    The transmission shifts smooth every time, so I don't think that is the issue, and it only happens when I come to a stop with the usual braking pattern or when I come to a stop quickly.
    Is this what axle wrap feels like?
  2. Sep 26, 2013 at 4:59 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
    It could be some axle wrap and have you checked for excessive play in the center carrier bearing on the drive shaft?
  3. Sep 26, 2013 at 5:00 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
  4. Sep 26, 2013 at 5:02 PM
    TrooperJoe
    TrooperJoe Member
    GA
    TRD Offroad
    Mines brand new with less than 2000 miles, I've been feeling a slight "surge" once I come to a stop as well, It doesn't bother me much as I've kinda gotten used to it.
    I notice it most when I've just come to a complete stop and my foot is holding the brake with slight pressure. When I hold it hard, there is no surge felt.
  5. Sep 26, 2013 at 7:27 PM
    Gooiegoogoo
    Gustavo
    Phoenix
    03 TRD SR5
    2" lift
    Carrier bearing is new, less than 10k miles but I guess I should check it out. Now that I think of it, it is more like a slam or thunk type feeling and my gut says that it has something to do with the drive line, could it be slip yoke, hasn't been lubed up for a little while now. Shit I bet that's what it is, what type of grease should I be using for that? I'll start there and see what comes of it.
    Thank you guys for the replies and thoughts.
  6. Sep 26, 2013 at 7:41 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Yep... sounds like axle wrap. Alot of people decribe the jolt/thud is so bad that they get out thinking they just got rear ended. Also, make sure your rear leaf spring u bolts are torqued down.
  7. Sep 26, 2013 at 7:49 PM
    Swank
    Swank Certified Mall Crawling Instructor
    Steven
    Greenville NC
    SOLD/TOTALED
    My truck is doing the same thing after we installed an AAL..
  8. Sep 27, 2013 at 6:38 PM
    toyotaman29
    Darrell
    North Carolina
    I like to use Red Line CV2, Militec 1 or Mobil 1 synthetic grease for all my grease fittings and wheel bearings, but any good brand should be fine, I grease mine every 5K when changing the engine oil.
