strange hesitation
Discussion in '1st Gen. Tacomas (1995-2004)' started by zookeeper, Feb 13, 2012.
  1. Feb 13, 2012 at 9:51 AM
    zookeeper
    zookeeper [OP] Member
    Big Bear,ca.
    03 double cab 4x4
    Any advise would be appreciated. When I apply gas from a dead stop I have a slight hesitation like a a miss fire or tranny issue, but when I replaced the plugs it went away for a few days . Now its back I live at 7500 ft and when I go down to 3000 it is much worse and seems to miss even when accelerating over 50mph. Any ideas?
  2. Feb 13, 2012 at 9:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    What plugs did you use to replace the old with? Were they dual ground electrodes?
    Try cleaning the throttle body and MAF.
  3. Feb 13, 2012 at 1:38 PM
    zookeeper
    Big Bear,ca.
    03 double cab 4x4
    Thanx I will try both of those next.
  4. Feb 13, 2012 at 1:45 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    mine does the samething. It's not always there and to be honest with you I haven't paid that close of attention to it. But my truck has had all the maintenance done and have replaced the plugs twice with the OEM's. Could be normal for our truck?
  5. Feb 13, 2012 at 8:54 PM
    The Goat
    The Goat New Member
    C.J.
    Boise, ID
    SR5 3.4 V6
    2 in. Icon lift and Centerforce stage 2 clutch
    It could be that your Trottle Position Sensor is bad or dirty. It could also be Mass Airflow Sensor is bad or dirty. Having a computer check for Diagnostic Trouble Codes (DTC).
    Hope this helps.
  6. Feb 13, 2012 at 11:57 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Let's see, before we go replacing expensive stuff. You replaced the plugs, but not the wires? Replace the wires.
  7. Feb 14, 2012 at 12:08 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    If it's running rich, that would explain why it's getting worse as you get closer to sea level.... hmmm
