Strange noise after steep downhill drive
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ancasme007, Oct 3, 2024.
  1. Oct 3, 2024 at 7:51 PM
    ancasme007
    ancasme007 [OP] Member
    Hey everyone, I wanted to get some opinions here if possible, I went on a small trip, this trip had a really steep downhill road (really, really steep) I was engine braking but still had to use the brakes quite a bit, got to a point they started smelling so I stopped. When. I started driving again I started hearing this damn noise. Once I finally got to the bottom, I stopped for a second and the noise stopped. I have no idea what It could be, so I’d appreciate any opinions guys.
    It’s a 2023 TRD sport.
    It seemed to be somewhere in the rear right side of the truck, but Im not so sure.
    Video link:
    https://youtu.be/AP9dLns19TY
  2. Oct 3, 2024 at 10:10 PM
    blacktaco77
    blacktaco77 Well-Known Member
    Noah
    21 TRD off road black 4x4
    I believe to have had that noise before a while ago but doing something completely different. Don’t ask why lol but my truck shut off after aggressively throwing into drive from reverse. Turned it back on and noise was there then went away after stopping for a second as well. Happened quite some time ago still don’t know what it was.
  3. Oct 4, 2024 at 5:50 AM
    ancasme007
    lol Yeah that’s so weird, same thing here, this was last weekend, and I haven’t heard it again since, makes me wonder what it could be , but hey, glad it stopped for you as well!
  4. Oct 4, 2024 at 6:27 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Did you get under and look or just take the video?
  5. Oct 4, 2024 at 8:53 AM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    I'm not a mechanic, but that sounds like metal scraping. Have you looked under the truck to see if there's anything obvious? If it stopped after you stopped the vehicle, then maybe you just have something loose that is shifting around and occasionally scraping. Or you might have picked up some debris (gravel etc) that worked itself loose on its own. Or your rear brakes are worn out.
    I like the gravel theory myself. I crossed a gravelly stream once and something similar happened to me. Worked itself out before I had to do anything.
    Also I'm still not a mechanic lol
  6. Oct 4, 2024 at 10:38 AM
    perchalot
    perchalot Well-Known Member
    San Diego
    2020 4X4 OR DCSB, 2014 DRZ400SM
    Does the cadence of the noise correlate with speed?
  7. Oct 4, 2024 at 1:28 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Stone stuck in rear drum. Happened periodically to me in Vermont, three different vehicles. Stone gets wedged driving forward. Go to a parking lot, put in reverse jam on the brakes. Repeat until stone is dislodged.
    Taco_Craig and Canadian Caber like this.
