Strange Noise.. (Audio)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DR007, Jul 7, 2013.
  1. Jul 7, 2013 at 9:32 AM
    DR007
    DR007 [OP] Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    Recently, in the past couple, days I've been noticing an almost clicking noise when I accelerate. I'm not sure what it is. It seems to be coming from the driver rear but heres a clip of it, I removed some of the wind and engine noise to better hear it from the clip.
    Time 0:01- 0:05 is when you can hear it the most.
    http://youtu.be/Owpo4DCuRsg
    Is it my leafs? But it seems to make the noise only at lower speeds (of what I can hear)
  2. Jul 7, 2013 at 9:35 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Maybe there is a heat shield loose on the underside? Have you crawled under and checked? Perhaps the CB is flopping around too... :notsure:
  3. Jul 7, 2013 at 9:37 AM
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    Ive checked for loose things and everything seems to be snug and tight. Nothings in the bed. I'll double check everything though.
