Strange noise coming from front of truck.....help!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09taco4x4, Aug 1, 2011.
  1. Aug 1, 2011 at 3:59 PM
    09taco4x4
    09taco4x4 [OP] Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
    I installed a 3" ProComp kit on 09 DCLB 4x4 TRD Sport. I also installed light racing upper control arms from ToyTec and they are set at 0. The noise sounds like a clunk or something shifting around up front when I accelerate or brake and turn left or right at low speeds. I have removed the sway bar and it still makes the noise and I jacked the front of the truck off the ground and turned the wheels left and right, the noise went away. So it's only if there's weight on the front end. I contacted ProComp to see if I could get some help from them and that's not going to well. I can't physically see anything shifting up front when looking at it while turning the wheel. I am stumped on this one..........
    I have already ordered some Walker Evans coil overs and Walker Evans rear shocks cause I just don't like the ride of the ProComp. I am just more concerned that it's not something else major up front.
  2. Aug 1, 2011 at 5:34 PM
    tcma07
    tcma07 Chris
    C.C. Texas
    2007 Sport 4x4 v6 A/C Blk
    4" lift, Satoshi, BHLM...
    i have the same exact problem im thinking its the tie rods they kinda look akward after my 3" lift
  3. Aug 1, 2011 at 8:17 PM
    09taco4x4
    Louisiana
    I was thinking that also. I will find out for sure if it is my ProComp coilovers when I replace them.
    I will keep ya posted!
  4. Aug 17, 2011 at 8:48 AM
    tcma07
    tcma07 Chris
    C.C. Texas
    I just fixed it my problem was that my lower control arm bolts were not tight enough after a quick hit with the impact good as new no more noise:D
  5. Aug 17, 2011 at 9:09 AM
    09taco4x4
    Louisiana
    What is the tourqe spec for the lower control arm bolts?
  6. Aug 23, 2011 at 10:40 AM
    09taco4x4
    Louisiana
    Tightening up the bolts fixed the problem. The retards from the delaership didnt tighten them up enough at all. The bolts were just little bit further than finger tight.
    The tourqe spec for all 4 lower control arm bolts is 155 foot lbs.
