Strange noise from the front end
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ahitaco, Nov 30, 2011.
  1. Nov 30, 2011 at 4:32 PM
    Ahitaco
    Ahitaco [OP] Member
    Dave
    Utah
    05' 4x4
    I have a 2005 Tacoma DCLB, while driving between 30 and 90 mph i hear a strange humming sound. I doesnt sound like the engine but more like from the wheel area. It is louder when i take my foot off the gas. I was told it was probably my differentials and that I just needed to change the fluid. I have done that and still getting the noise. any suggestions on what it could be and how i can fix it.
    Any help is appreciated
  2. Nov 30, 2011 at 4:33 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    not to be a smartass..but...tire hum?
  3. Nov 30, 2011 at 6:38 PM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Front differential bearings? Wheel bearings? Driveshaft U-joints? :notsure:
  4. Dec 1, 2011 at 8:10 AM
    Ahitaco
    Ahitaco [OP] Member
    Dave
    Utah
    05' 4x4
    I don't think its wheel hum, I have the truck for 4 years now and have always put the same tires on. The noise started only about 6 months ago, It went away for the most part when i changed the rear differential fluid, I should say it got quieter, now its getting louder again.
    gregman- how could i check the bearings or the drive shaft u joints with relatively inexpensive ? or do i have to take it in to the dealer?
    Thanks again
  5. Dec 1, 2011 at 8:16 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Check wheel bearings by jacking one of the front tires off the ground and trying to move the wheel assembly without shaking the truck. You shouldn't have any play in the hub, if you shake the wheel up and down or front to back, it should not move without moving the truck.
    For the U-joints, get under the truck and see if there's any play across the u-joint. If the u-joints get really bad, you'll feel a 'clunk' when you put it in drive or reverse as the slack is taken up.
  6. Dec 1, 2011 at 10:09 AM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    It could be the wheel bearings, and what Pugga said is correct. But i also wanted to add, in my experience with these taco wheel bearings, mine had no play but was still bad. There was some pitting that was forming in my passenger side front wheel bearing that would make a kind of grindy/hum noise that I bet is similar to yours. Which would account for why it was not loose but made the noise and i could also feel a vib from it at 20mph+
  7. Dec 1, 2011 at 10:13 AM
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2010 DBLC 4x4 Off Road
  8. Dec 1, 2011 at 1:58 PM
    Skadumz
    Skadumz Well-Known Member
    Lehigh Valley, PA
    2008 tacoma dual cab, long bed, 4x4, TRD Spor
    3" lift 265/70/17 nitto, Grille Craft Grille, Tinted windows, 17x9 Moto Metals Matte Black, Carrier barring drop
    I have had this same problem for a while now. I have taken it to the dealer and they had the field rep out beacuse the technician didnt know where to look for the noise. The field rep told me to let it get worst so they can really dial down an area. I think that is a load of crap. But I got the front diff fluid changed and the transfer case, no change. but I did notice that where the CV joint goes into the diff there is alot more play on the drivers side then the passengers side. any ideas>
  9. Dec 1, 2011 at 2:28 PM
    lundy
    Justin
    Reno, NV
    put it in 4WD and see if it still makes the noise. If it goes away then its the diff bearing from what I've read.
  10. Dec 1, 2011 at 2:45 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I was going to say hummingbird but sounds like wheel-bearing :D
  11. Dec 1, 2011 at 3:07 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    First thing coming to my mind, put it in 4WD, see if it goes away. Get it in ASAP before Toyota finds a way to blame it on you :)
    Don't ask... lol been there done that.
  12. Dec 1, 2011 at 3:09 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I've got a noise that kinda sounds like this coming from the front drivers side. At slow speed it's kinda rhythmic, louder/softer then when I get to speed I can hear that it's there constantly when I drive past something solid. I need to get it looked at before it fails completely.
  13. Dec 4, 2011 at 10:19 AM
    Ahitaco
    Ahitaco [OP] Member
    Dave
    Utah
    05' 4x4
    It was the front left wheel bearing, thanks for all your help.
  14. Feb 1, 2012 at 3:19 PM
    Skadumz
    Lehigh Valley, PA
    well sorry it has been awhile. But yet another fail by another dealer. they said it sounds normal. I am very certian it isnt. it happens between 15 and 35 mph. I am not in a position to start riping into things myself. Any suggestions? or how much it would cost just to get it done at a garage?
  15. Feb 1, 2012 at 5:14 PM
    LTC Taco
    LTC Taco Member
    I had the same problem and needed to replace the left front bearing. Drives like a charm now.
  16. Feb 1, 2012 at 5:23 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    I've got the same thing. Rhythmic humming that is loudest between 50 and 60 mph but I can hear it at slower speeds. Does not go away in 4WD.
    So... anyone know if front wheel bearing are covered in the powertrain warranty? My regular warranty just expired (along with my payments) a couple months ago. Otherwise it looks like I'll have to brush off my mech skills and tear into it.
  17. Feb 27, 2012 at 1:44 PM
    Skadumz
    Lehigh Valley, PA
    Well if you have a lift on the truck then nothing is warranty. if not then yes. Just failed again at another dealer. they said for sure it was the diff but would not reaplce under warranty due to the lift.:mad:
  18. Jan 25, 2015 at 1:01 PM
    good vibes
    good vibes Well-Known Member
    mike
    NC
    2014 tacoma double cab
    3" lift 20" hostile rims toyo open countrt
    How many miles are on the truck now , just wondering I replaced my bearing with the bushing and still get the vibe but was told it won't hurt anything
  19. Apr 14, 2015 at 2:48 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I recently began to feel a humming/vibration in the floor at about 65 mph. The feeling cycles on and off when I hold the truck at that speed, and I'm pretty sure it occurs at between 50 mph and 60 mph, just not as bad.
    I have a bit of road noise from tires (Wrangler Duratracs), but this feeling is different.
    There doesn't seem to be any grinding in the hub when I spin the tire with each side jacked up, and I don't feel any wiggling in the wheel when I pull top/bottom and side/side. Rotating the tires didn't help.
    Could this rhythmic vibe still be due to a bad wheel bearing, despite my checks not showing anything?
    FWIW, suspension is at stock height. I don't suspect the diff bearing to be an issue here, as I got rid of that when I lowered the truck to stock height many miles ago.
  20. Apr 14, 2015 at 2:50 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    hears weird noise at 30mph... GUN IT TO 90!!!! :rolleyes:
