STRANGE NOISE IN FRONT END WHEN TURNING
Discussion in 'Technical Chat' started by 08yodatoy, May 30, 2012.
  1. May 30, 2012 at 3:26 PM
    08yodatoy
    08yodatoy [OP] Member
    joe
    Ok
    08 sr5 trd silver
    trd cold air, fowmaster cb exhaust ,leveling kit, pro comp 8128, pro comp mud terrain tires
    im pretty new to this forum and im decently familiar with my truck and working on it but i definitly dont know everthing by a long shot.
    anyhow, i have an 08 with the trd off road package it has a trd cold air intake and a trd exhaust and i had the 2.5" spacers in it that just went right above the coil over, after running those for a while i started to hear a slight noise in the front end when i turned and hit a bump or when i just turned really hard in either direction, i looked under my hood and seen that my upper ball joints were shot and that my upper control arm was binding the coil when the suspention was fully extended soo... i did alot of research and learned that i pretty much screwed my self using those spacers and to fix it i went ahead and replaced upper control arms and coil overs with products by camburg!!
    now with all that being said i still have the noise its just one thud when turning either direction while moving it doesnt make the noise when im not in motion!!!!!
    i could really use some help
    thanks
  2. May 31, 2012 at 6:18 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
    what size tires are you running
  3. May 31, 2012 at 6:20 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^X2, wonder if the front tire is rubbing against something when turned.
  4. Jun 1, 2012 at 6:05 AM
    08yodatoy
    joe
    Ok
    08 sr5 trd silver
    285 70R 17
    Iv thought about that being the problem but the sound that I hear sounds like something metal hitting the floor board and it's just one solid thud when I hit a bump or a hole while turning, it could be my tired but idk how I would test to rule thaw out besides putting some sock wheels on it which I don't have??
  5. Jun 1, 2012 at 5:13 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    dust your fender well with dirt or sand or lie(cal) and see if it marks.:burnrubber: remember that the spacer had the prob (arm)with it extended not compressed (spring). :rain:
    what offset are you running for your wheels. 285 are fat they need offset.
  6. Jun 1, 2012 at 5:19 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    X2
    or just look and see if there are signs already since the noise has been happening for a while the should be marks.... Also have you checked and made sure all the bolts are tight :confused:
  7. Jun 21, 2012 at 6:27 AM
    Izzapac
    Izzapac Member
    St. Robert, MO
    2007 TRD Sport Silver Streak
    Bilstein 5100s front (1.75") & rear
    I've searched to see if anyone was experiencing the same problem as me, but couldn't find anything to be quite close enough. I am running 265/70/17s with billie 5100's all around, 1.75" setting in front. I was experiencing a rubbing/grinding noise when turning left or right. Kind of a "Whir-whir-whir". The intervals of the sound seemed to speed up and/or slow down according to my speed. I checked for rubbing all over, and found no evidence of rubbing. I put Spidertrax 1.25" spacers x4, and the noise is still there, not better or worse. Is there a component that is beginning to fail? Or is something rubbing in an area where I just can't see it? I've checked all fender areas, UCAs, mounts, etc. No rubbing seen, and no indication of rubbing on tires. Very frustrating. Any help is GREATLY appreciated.
  8. Jun 21, 2012 at 11:25 AM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    there are several threads about trimming the wheel well panels. you most likely need to do this. look at bullet's build pics a think he shows pictures. your tires are as tall as mine.mine 75/16 yours 70/17 is the same.oh and one more thing
    :worthless:
