Strange noise in the cab of my 2003...
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfpackbd22, Oct 25, 2017.
  1. Oct 25, 2017 at 6:38 AM
    wolfpackbd22
    wolfpackbd22 [OP] Well-Known Member
    Brandon
    This is a long shot because it's a very unique noise and I don't know what is causing it but maybe someone else has had this happen. In my 2003 I have the transfer case shifter with the 4wd button. When I am at idle, I can hear an intermittent buzz every few seconds coming from right around the transfer case gear shift. It sounds like the actuator that you would hear when you press the button and it shifts into 4wd. I can't hear it from underneath the truck, and it doesn't actually shift into 4wd it just sounds like it is trying to. Very unique problem and I have no idea where to go from here so maybe someone has some input. Thanks
  2. Oct 25, 2017 at 7:42 AM
    indetrucks
    indetrucks Well-Known Member
    Christian
    Southern CA
    Supercharged 03 TRD Tacoma 4x4 Xtra Cab 5spd
    I have the same truck and have never heard the noise you describe.
    Hopefully someone else can help
    wolfpackbd22[OP] likes this.
  3. Oct 26, 2017 at 2:55 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Could be the A/C temp door moving. Mine does it once and awhile. If I just move the temp dial a little it quits. Try turning it from cold to hot and back about 40 times. That fixed mine.
  4. Oct 27, 2017 at 6:30 AM
    wolfpackbd22
    Brandon
    I can't wait to try this when I get back to my truck later today. If this works you're the man. It's been driving me crazy
  5. Oct 27, 2017 at 10:54 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    I thought i had dam gremlins in my truck. LOL
  6. Oct 27, 2017 at 12:40 PM
    Glamisman
    Glamisman Well-Known Member
    under the center console there is a Solid State control unit... I think for seat belt warning, it been a while, and the shift interlock... the gizmo the requires you to have your foot on the brake to take it out of park... if you have an automatic. Taking the shift cover off is easy then you can stick your fingers in there and see if you can feel anything vibrating.
  7. Oct 29, 2017 at 12:16 PM
    wolfpackbd22
    Brandon
    I can't believe it. It was the A/C actuator and playing with the temperature fixed it. I thought my 4wd button was stuck and my transfer case was going to eventually explode. I can't believe it was something so stupid
    mechanicjon[QUOTED] likes this.
  8. Oct 29, 2017 at 1:39 PM
    mechanicjon
    Jon
    Scottsdale Arizona
