Strange noise please help!
Discussion in 'General Tacoma Talk' started by Nazareth7, Jun 13, 2024.
  1. Jun 13, 2024 at 6:56 PM
    Nazareth7
    Nazareth7 [OP] Well-Known Member
    2007 Tacoma 2x4
    Hello beautiful community, I have this range noises coming from the back and front tires of my Tacoma , I checked my brake pads and rotors look new. The sound is picking up with my tire rotations . But disappears at higher speeds. Yes my wheel bearings are good. And ujoints are brand new. The noise is coming from the wheels area.
    Update it came out to be my wheel covers lol
    https://youtube.com/shorts/7aiB-ESPrTE?si=JX1NX0wX_eCpESKK
    HondaGM likes this.
  2. Jun 13, 2024 at 7:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you checked the wheel bearings lately?
    HondaGM likes this.
  3. Jun 13, 2024 at 7:20 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Or ujoints
    HondaGM likes this.
  4. Jun 13, 2024 at 7:34 PM
    Nazareth7
    2007 Tacoma 2x4
    My ujoints are brand new
    HondaGM likes this.
  5. Jun 13, 2024 at 7:34 PM
    Nazareth7
    2007 Tacoma 2x4
    Yes seems good
    HondaGM likes this.
  6. Jun 13, 2024 at 7:49 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Got a video of the noise?
  7. Jun 13, 2024 at 7:54 PM
    Nazareth7
    2007 Tacoma 2x4
    I added a video of it from my YouTube .
  8. Jun 13, 2024 at 7:56 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    You lifted the truck and spun the wheels by hand to see if you can duplicate the noise?
  9. Jun 13, 2024 at 7:59 PM
    Nazareth7
    2007 Tacoma 2x4
    Yes I have done that it’s not actually making the noise for that . Maybe I’m not spinning them hard enough.
  10. Jun 13, 2024 at 8:06 PM
    soggyBottom
    soggyBottom Well-Known Member
    Does it sound different on the passenger side?
    If you have 4 jack stands, you could try putting it in drive while in the air. Unless it's from the front and you have 2x4.
    Even with 2x4 you could try pulling the wheels off while jacked up. Spin them with your hands and try to feel for any drag there may be.
  11. Jun 13, 2024 at 8:13 PM
    Nazareth7
    2007 Tacoma 2x4
    it’s rear wheel drive Tacoma .
  12. Jun 14, 2024 at 5:02 AM
    soggyBottom
    Pull the wheels off, and see if you can fee any friction when you spin them.
  13. Jun 14, 2024 at 12:07 PM
    Motafinga
    Motafinga Member
    First gen Tacoma TRD
    Maybe check for rubbing of the disc heat shields they are just sheet metal and can get easily bent during service. I would also check the brake pad anti-rattle clips as those can get cock-eyed and make noise.
  14. Jun 15, 2024 at 1:03 AM
    Nazareth7
    2007 Tacoma 2x4
    I checked they seem good, but the rear drums are also making same noise with the front ones. It’s very strange that they have the same noise at the same coming from front and back.
  15. Jun 15, 2024 at 2:18 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Was the noise happening before you changed the ujoints?
    New doesn't always mean good.
    Are they greasable? was there grease in them?
  16. Jun 15, 2024 at 10:08 AM
    Nazareth7
    2007 Tacoma 2x4
    They non grease ujoints. and no changed my ujoints months ago, and this noise is days old.
  17. Jun 15, 2024 at 10:15 AM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    After rotating my tires once ..the balancing weights would hit my brake calipers causing a similar noise ...16x8 wheels 4.5 backspace
    Motafinga likes this.
  18. Jun 16, 2024 at 9:19 PM
    Nazareth7
    2007 Tacoma 2x4
