Strange noise Tacoma Prerunner
Discussion in 'New Members' started by Riddle, Jun 27, 2013.
  1. Jun 27, 2013 at 9:24 PM
    Riddle
    Riddle [OP] Active Member
    Tyler
    2001 Prerunner 2.7l
    First off I would like to say hi! I recently(3 months ago) purchased a 2001 Tacoma PreRunner after wanting one for so long for a daily driver. Well all has been well I changed the oil for the first time (used Mobil 1 and Mobil 1 filter) then changed fuel filter, trans fluid and rear end fluid then spark plugs. Pretty much changed everything so I knew everything was fresh. Well here recently I've been noticing on warm start up after sitting for 10-15 mins the truck seems to knock not a loud knock but you can hear it from under neath the truck. I'm really not too sure what it is or where to start. It doesn't make this sound on cold start up and if you rev the truck after warm start up while its making this sound the sound goes away. Then comes back as the idle drops back down and then goes away around 60 seconds of the truck running. Its a 2.7l and only has 120k on it. Any ideas or thoughts? I have googled this and can't find anyone with this problem.
  2. Jun 28, 2013 at 7:19 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    So ... it did NOT make the sound BEFORE you changed fluids?
  3. Jun 28, 2013 at 8:00 AM
    Riddle
    Tyler
    2001 Prerunner 2.7l
    No it did not. I even changed the oil back to what the other owner had in it. However I did not know what kind.
    Of filter it had on it before so that's why I put the Mobil 1 on it
  4. Jun 28, 2013 at 10:39 AM
    270wsm
    270wsm Well-Known Member
    AZ
    Are you using full synthetic oil?
  5. Jun 28, 2013 at 12:16 PM
    tan4x4
    Rick
    Folsom, CA
    Next, I would try an OEM oil filter from the dealer. I believe they have an anti-drainback valve that many aftermarket filters do not.
    I never use anything but OEM oil filters on my Toyotas.
  6. Jun 28, 2013 at 1:10 PM
    Riddle
    Tyler
    2001 Prerunner 2.7l
    Yes I'm using Mobil 1 full synthetic is that bad? And Rick thank you I did not know that I will go first thing in the morning to Toyota and get a oil filter and switch them out. The filter could cause this slight knock on warm start up?
  7. Jun 29, 2013 at 11:31 AM
    Riddle
    Tyler
    2001 Prerunner 2.7l
    I switched to Toyota oil filter and it still makes the sound upon warm start up
  8. Jun 29, 2013 at 11:37 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    It coul be the synthetic oil could be to thin might wana try regular oil
  9. Jun 29, 2013 at 11:45 AM
    Riddle
    Tyler
    2001 Prerunner 2.7l
    Is there an oil that you reccomend?
  10. Jun 29, 2013 at 11:56 AM
    BAMFTACO
    Juan
    Kings bruh
    Try non synthetic or a little bit thicker viscosity synthetic oil.
    Hopefully some else with a 2.7 might now
  11. Jun 29, 2013 at 1:34 PM
    Riddle
    Tyler
    2001 Prerunner 2.7l
    I went to Walmart changed the oil to regular Castro GTX conventional oil and the sound is completely gone on warm start up. I guess the synthetic was breaking down when warm. Thank you!
  12. Jun 29, 2013 at 4:40 PM
    Riddle
    Tyler
    2001 Prerunner 2.7l
    After driving the truck to work and letting it sit for 15 mins I went out and started it again to make sure the noise is gone. Well its back now same knocking noise as before I have no clue what it could be
  13. Jun 30, 2013 at 10:38 AM
    270wsm
    AZ
    Do u know exactly where the knockn noise is coming frm? is towards the rear engine,
  14. Jun 30, 2013 at 10:53 AM
    Riddle
    Tyler
    2001 Prerunner 2.7l
    Somewhat, as much as I hate to say it it almost sounds like its coming from the oil pan
  15. Jun 30, 2013 at 11:17 AM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Did u buy from a dealer or private party? What did the old oil look like when you first changed it? The knock could have been there previously but the previous owner could have covered it up by using gear oil mixed with regular motor oil, or any other form of masking a small engine knock. Sometimes just using ad additive like Lucas can cover up a knocking sound.
  16. Jun 30, 2013 at 11:27 AM
    Riddle
    Tyler
    2001 Prerunner 2.7l
    I bought from a private party. The guy always took the truck to this place to get the oil changed beside his work. He even had all the reciepts for it. Pennzoil oil was always used. It was.changed maybe 1500 miles before I bought the truck and the oil looked brand new when I drained it
  17. Jun 30, 2013 at 11:34 AM
    Mainmoe02
    Moe
    Austin, Texas
    Well that's a good sign then!
  18. Jun 30, 2013 at 11:38 AM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
  19. Jun 30, 2013 at 11:40 AM
    Riddle
    Tyler
    2001 Prerunner 2.7l
    What's the popcorn for? Lol
  20. Jun 30, 2013 at 11:41 AM
    drunktaco
    Sage
    Southwest Va
    Haha I'm just interested in what the out come of this is.
